throttle position sensor location?
Old Aug 27, 2011 | 07:44 PM
jreyes916's Avatar
Car: 89 camaro
Engine: 5.7 from an 89 blazer
89 camaro with a 5.7 from an 89 blazer where is the TPS located?
Old Aug 27, 2011 | 08:22 PM
Damon's Avatar
Re: throttle position sensor location?
Passenger side of the throttle body. 3 wires.
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
If it is a tbi (L05) then it is located on the front of the throttle body, passenger side.
Old Aug 27, 2011 | 08:33 PM
jreyes916's Avatar
Car: 89 camaro
is that the iac valve?
Old Aug 27, 2011 | 08:39 PM
I think it is the tps. I just replaced mine last fall. Plastic with three prongs.
Old Aug 27, 2011 | 08:48 PM
jreyes916's Avatar
Car: 89 camaro
the only thing i see is the idle are control valve and its metal. i am trying to adjust my idle and some one said to adjust the tps. so being that said does the tps have a adjuster?
Old Aug 27, 2011 | 09:09 PM
I don't think so. I think the L03 tbi is basically the same as the L05
Old Aug 28, 2011 | 01:47 AM
jreyes916's Avatar
Car: 89 camaro
so how do i adjust the idle
Old Aug 28, 2011 | 01:50 AM
jreyes916's Avatar
Car: 89 camaro
and i found the tps
Old Aug 28, 2011 | 08:27 AM
There is an idle adjustment where your throttle cable ends. Let it warm first.
Old Aug 28, 2011 | 05:56 PM
jreyes916's Avatar
Car: 89 camaro
ok so how do i adjust the cable? sorry for the questions
Old Aug 28, 2011 | 06:05 PM
jreyes916's Avatar
Car: 89 camaro
oh yeah and i heard that if you adjust the cable then you have to adjust the sensor as well to the right voltage is that right
Old Aug 28, 2011 | 06:12 PM
There is now way to adjust the tps, just install it. As far as throttle adjustment, take of the air cleaner and you should see the adjustment at the linkage. It's very easy.
Old Aug 28, 2011 | 11:11 PM
jreyes916's Avatar
Car: 89 camaro
im gonna post the pics i see no adjuster
Old Aug 29, 2011 | 08:52 PM
jreyes916's Avatar
Car: 89 camaro
ok i cant upload pics but there is no adjuster just a loop at the end that goes around a little post that is unmovable
9192camaro
16
Feb 3, 2019 12:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
