What are the best cams to go with?
Old Sep 6, 2011 | 09:18 PM
SXN's Avatar
SXN
As the title states, what cams should I go with guys?
My car is stock and I just want more power out of it.
It's a 5.0L
Thanks in advance
Old Sep 6, 2011 | 09:47 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: What are the best cams to go with?
It's a 5.0L
Thanks in advance
We will need more information to truly help you.
Post the Year/Model of the car, along with the Engine/trans combo.
Aka, 1989 TransAm GTA, 5.7L TPI Auto.
Though I'm guessing you are talking about your Recaro TA. I'm not sure what engine you had. Crossfire, L69?
Old Sep 6, 2011 | 09:49 PM
SXN's Avatar
SXN
Sorry bout that bud.
It's a 1984 TransAm with a 5.0L HO Auto.
Appreciate the input.
Old Sep 6, 2011 | 09:56 PM
I'm guessing you are starting out with an L69 then which is a non-roller block.
I suggest giving CompCams a call and seeing what they recommend for a stock head/block 305.
I however would skip the cam at first, and go with intake and exhaust mods. Headers, cat-back....
Not too sure on intake options for the L69.
Old Sep 6, 2011 | 10:04 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
PS what is your real goal 10HP - 200hp above stock
as above heads, exhaust, intake, then a cam... and more cfm flow
Old Sep 7, 2011 | 04:40 PM
SXN's Avatar
SXN
I just want more power.. but I don't wanna overpower the tranny either.
Just a little more to keep it fun to drive.
How much are intakes and what brands should I look at?
Thanks guys
Old Sep 7, 2011 | 04:47 PM
Forget the Cam idea if you only want "a little more power".
If thats the case look into intake and exhaust mods. Do full headers and cat-back as well as intake upgrades. Don't even bother with a cam or heads.
Cam and heads is for people who want to keep the same platform but want serious power upgrades, its too much $$$ and work otherwise because you need the intake and exhaust mods to go with it. Then again, I don't know if I would go beyond full exhaust on a L69, or any flat tappet 305. I'd probably just jump straight to a 5.3L engine swap.
Old Sep 7, 2011 | 08:53 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
You could go with a edelbrock performer manifold and matching cam. That would give you a decent pick up over that stock peanut cam. But you should start with the exhaust first.
Old Sep 8, 2011 | 10:20 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I agree with Thirdgen89GTA. Do the intake & exhaust if you just want "a little more power". Otherwise, get a better cam, better heads, better intake, headers, etc.
Old Sep 8, 2011 | 12:52 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Another +1 here.
The only problem with intake and exhaust is good parts can have you spending over $1000.... for 20hp. You get a lot more power for your money with cam/head swaps, but you run into the problem of needing the intake and exhaust ot keep up with hte cam.
So where does this leave you?
Depends on how much money you feel like spending.... I'd probably just save for a 5.3/5.7/6.0 swap myself. Even then,you'er gonna have to invest in good exhaust for a swapped in engine to work.
The ball is in your court, I dont think the ROI for a good exhaust is really worth it on stock or near stock engines, but the difference in sound helps make it worth it. And if you want more power exhausti s something you WILL have to do eventually.
Old Sep 8, 2011 | 01:40 PM
Can do Cheapie headers and a cat-back for about $800 or so I would think. Maybe less.
Would it be the same as spending for a set of coated 2055 or Dyno Don headers and a stainless steel cat-back? No, but it would provide an increase in power. Besides, its just an L69, with a set of mid-range shorty headers and a cat-back it'll breath alot better up top where the L69 likes to be.
From there you can either stop, or plan an all out build. Personally if its an all out build I'd change to a Gen3/4 SBC like a 5.3L. They make some GOOD power. The cost of getting an L69 to the same level of power as a 5.3L would be compariable.
Could go to a carbed 5.3L and make some good power.
Old Sep 10, 2011 | 10:50 AM
SXN's Avatar
SXN
Thanks for the input guys. Whats the best online website to buy performance parts from? I looked at the oem headers and couldn't believe how restricted they looked.
Old Sep 10, 2011 | 10:53 AM
https://www.thirdgen.org/forums/exha...ion-chart.html
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
