ignition switch?
Old Sep 24, 2011 | 01:00 PM
built's Avatar
Car: 82 TA
ignition switch?
On my 82 ta when I turn the key nothing happens, I have a dome light and headlights come on but won't rotate to up position. I have removed and checked the alternator,battery and charged it fully to make sure.
it has a new starter.
when I turn the key the lights do NOT dim so i'm thinking it's the ignition switch.
What is the procedure for replacing the switch, is it much trouble?
Old Sep 24, 2011 | 06:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: ignition switch?
Remove under dash panel
Two large nuts, hold the bracket for under dash panel - remove
Two more large nuts, hold steering column up to dash - remove and let column drop as far as wires will allow.
You'll see the ignition switch on top of the steering column - if an automatic you have to remove the back half from the switch before you can remove the switch from the column.
Before you go throug all this - I'd get a VOM and read: http://www.austinthirdgen.org/index.php?pid=38
Old Sep 24, 2011 | 09:10 PM
built's Avatar
Car: 82 TA
I can get a vom but I'm not good with using them.
i'll try but i don't know what to check or how and what to do then.
I appreciate your help and I know it's hard to teach online but any help you can give I do appreciate.
thanks.
Old Sep 25, 2011 | 01:59 PM
built's Avatar
Car: 82 TA
One more thing that bugs me, why won't the headlights open up with this problem, the lights come on but don't turn up.
Are the controlled somehow with the ignition?
Old Sep 26, 2011 | 11:24 AM
robster186's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
91 Z28 5.7 TPI. Pulle dinto the driveway and shut it off. Ran in teh house and came back out. Wouldnt start. Only has partial ACC power. Dome light, radio, turn signals. Read some of these posts with the same problem. I replaced the Ignition Switch and still same problem. Any suggestions?
Old Sep 27, 2011 | 05:32 PM
built's Avatar
Car: 82 TA
Found my problem, turned out to be a broken wire at the starter, replaced that wire and it started up fine.
thanks for all the help.
Old Oct 15, 2011 | 12:06 AM
Jetlifejimmy's Avatar
I have a question. I have a '92 camaro RS and majority of the times it doesn't start. I have a new alternator, a good battery, and good starter (took them to auto zone). When i try to start it just makes a click noise and the lights and radio usually come on. Those times when it won't start, the oil gauge is low for some odd reason even though there's nothing wrong with the oil. Also when its low i get jump starts and it works but as soon as i turn it off it wont start back up again. I heard it could be the ignition switch but i don't understand how the ignition would affect the oil meter. What do you think could be the problem??
Old Oct 15, 2011 | 02:01 PM
robster186's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
It was my experience with my '91, that the ignition switch having issues and going out, will not allow the vehicle to start, BUT does allow SOME ACC power. I had dome lights, radio, SOME gauges, turn signals, but nothing else. I replaced the ignition switch, but I apparently had other issues as well. I had to replace my steering column, due to the rod was not making connection to the key cylinder all the time. I also apparently had a broken wire inside the insulation areoun the coil wire. I would imagine that my additional issues are not similar to your, fortunately for you.
Replacing the ignition switch wasnt as bad and difficult as I expected. Hopefully that is your only issue. Since I have basically replaced my entire ignition system, hopefully I can assist you with your issues
Old Jun 14, 2012 | 06:02 PM
maxdvd91's Avatar
Car: 1989 chevrolet camaro
Engine: 2.8l v6
Transmission: 700r4 rebuilt
Axle/Gears: stock
will a malfunctioning ignition switch mess with my all my acc including
radio headlights power hatch power locks heater blower motor and things
Old May 26, 2014 | 10:06 AM
Graphite07's Avatar
i have the same problem, car started fine made 2 stops on the 3rd stop i come out and car would not start. it could be the Ignition switch now i am reading it could be the wires to the starter. but the starter kicks over when place a screw drive to the battery wire to the soleniod lead. maybe my problem is the ignition switch.....
Old May 27, 2014 | 06:27 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...formation.html
Old May 27, 2014 | 08:57 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
After you complete your Profile Info (so we know what you're working on) you should understand that just because the starter works when you bypass it doesn't mean you have all the wires connected to it or that they're tight or that you don't have a blown fusible link. The starter motor acts as a junction point for several positive wires to connect to each other.
Old Sep 23, 2018 | 09:39 AM
Nolanwayne1's Avatar
Ok so I have a 1989 camaro RS with a 305. And one day when I parked it I turned the key off but the security light stayed on and the Ecm started smoking. Now I can’t get it to start at all. I replaced the ignition cylinder but that didn’t help. What do y’all suggest?
Old Sep 23, 2018 | 12:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Post #6
https://www.thirdgen.org/forums/dfi-...-ecm-fire.html
new ecm ? Have you verified the power wires and grounds at the ecm ?
there is a inline fuse next to the battery.
Old Sep 23, 2018 | 12:43 PM
Engine: Lb9
Transmission: M20
Old Sep 30, 2018 | 08:35 PM
3GENBIRD's Avatar
Car: 88 TRANS AM 86 MONTE CARLO 75 VERT
Engine: TRANS 5.0 MONTE LS2 75 CAPRICE 454
Transmission: 700R4 4L60 TURBO 400
Axle/Gears: 373 410
How's it going did you ever find out the problem ?? I have a 88 trans am an was driving it 2 nights Ago an turn off an now won't turn over or crank an all still have light's radio ex i change out the ignition starter switch an still Nutting any idea what it can be
Old Mar 14, 2019 | 12:42 PM
yeud619's Avatar
Car: 84 Camaro and a 82 camaro
Engine: Both are 5.7 litters
Transmission: Both are manual transmission
Axle/Gears: Both 3.73
I have the same dilemma with my, blasted ignition start switch. I had one of the red wires that attach to the starter cut and not connected, yet it worked fine for years? I read here one installs both on the battery side of the starter solenoid I did that, and still it would not start. Im changing the the switch at the column now. Anyone know of how my car started without that other red wire being installed on the starter?
Old Mar 30, 2019 | 12:36 PM
yeud619's Avatar
I replaced what seems as everything: ignition dimmer switch, battery, key tumbler, starter, fusible link good, msd good, and only clutch safety switch left to replace, any help?
Old Aug 8, 2021 | 12:07 PM
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
I am switching out my steering column with a tilt, own 88 formula, the ignition switch is backwards, from my old column when hooked up wires to new column got power to the fuel pump hear it kicking on but when i go to start car nothing, no starter trying to kick in, no crank,
This is an auto, I think I might know, but not sure the little black cyl with a cable coming out of it the neutrel safty switch
fishyz
Aug 6, 2011 01:41 AM
blackbetty89
Oct 15, 2005 10:08 PM
88firebird
Sep 10, 2004 11:35 PM
Flash84Z28
Apr 2, 2003 10:26 PM
jdb8797
Oct 2, 2000 08:50 PM
