big trouble! any ideas?
Old Dec 2, 2011 | 09:40 AM
SaltLifeCamaro's Avatar
Car: 86' Iroc-Z
Engine: tpi 350 small block
Transmission: a4 :)
Axle/Gears: bone stock for now
so in my 87 camaro, small block 350 tpi, we have sheared the bold heads off the thermostat housuing. one of them has a little stubby sticking out still i tried channel locks and vice grips but the bolt is stuck. well they both are, i have tried sprays, tapping with a hammer. every little trick i know. any help or suggestions would be great.
Old Dec 2, 2011 | 10:55 AM
Z06 FAN's Avatar
Car: 87 Iroc
Engine: built 355, 450HP
Transmission: built 700r4
Re: big trouble! any ideas?
Try an easy out, they always work for me. Any auto parts store should carry them or harbour freight.
Old Dec 2, 2011 | 02:07 PM
Car: 86' Iroc-Z
Transmission: a4 :)
u think it will work for the other one to? they both broke but only one has a stubby. the other is flush with the manifold. thanks
Old Dec 2, 2011 | 02:52 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
If you do a search, this question was just on here a month ago?https://www.thirdgen.org/forums/sear...archid=4531187
Old Dec 2, 2011 | 03:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tech...lt-busted.html
Old Dec 4, 2011 | 08:55 PM
Car: 86' Iroc-Z
Transmission: a4 :)
thanks everyone decided just to replace the intake manifold way safer route prolly same head ache.
Old Dec 5, 2011 | 07:02 AM
Grind or file the bolts ABSOLUTELY FLAT; mark them carefully in the EXACT CENTER with a center punch; drill STRAIGHT into them with a small bit, like a 1/16"; re-drill with successively larger bits until the remains of the bolt come out; finish with the bit for a Heli-Coil of that size (will take a 25/64" bit", Heli-Coil them, and put back together with STAINLESS STEEL bolts.
No need for replacing the manifold. Especially since there's no "direct" "replacement" available except a junk one which is equally likely to have the EXACT SAME problem.
Old Dec 5, 2011 | 11:42 AM
Z06 FAN's Avatar
Car: 87 Iroc
Yes it will work for both.
drill a small hole in the center insert easy out and turn till it comes out.(use heat if needed)
Its that easy
Should only cost yo 5 bucks
Old Dec 5, 2011 | 02:37 PM
MD83Z's Avatar
Best to drill and pick out the remaining bolt or use a reverse turn drill bit that grabs the last bolt parts out....When the easy-out snaps off you will add 2 extra hours tryin to get the hardened metal out....
Old Dec 5, 2011 | 05:17 PM
Avoid EZ-Outs... about 99.999% of the time they break off, and then you have a REAL mess on your hands, because they're ALOT harder to drill than a bolt.
Drill it. Don't try the other.
Old Dec 5, 2011 | 05:23 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I usually go the drill out route too if access isn't an issue but I've also heard you can weld another bolt on top of the sheared off bolt. Might have the same issue if it's still really seized but it may be another option.
Old Dec 5, 2011 | 05:25 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Correction. Not another bolt. A nut and weld inside it to the sheared off bolt.
Old Dec 6, 2011 | 09:05 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
And use anti sieze on the new bolts before you put them in!!!
Old Dec 6, 2011 | 01:39 PM
SomethingWild's Avatar
There's been many times where I couldn't get a bolt off with channel locks or a vice, but I like to always keep a pipe wrench handy because the way it gets tighter as you turn it, has always worked for me on any occasion.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
sreZ28
Aug 14, 2015 07:48 PM
