bad egr temp sensor ?
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
will a bad egr temp sensor throw a code 32 on startup, i am not really familiar with the syste orm did some searches and not clear on it from what i read sounds like the ehr system does nothing at idle so was wondering why code 32 on startup. I had to rewire my temp sensor but not sure if it works or not i am not sure if the orignal wire was even connected becaus eit seemed like the wire was severed any info would be great thanks
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: bad egr temp sensor ?
Code 32 only shows up when the computer operates the EGR system (while driving)
and doesn't see the EGR temp sensor working.
This could be because of faulty wiring and not that the sensor itself is bad
Trouble Code 32 EGR SYSTEM FAULT
Code 32 indicates a malfunctioning EGR valve,
a malfunctioning EGR temperature diagnostic switch, or an open or short to ground in the circuit
Have you cleared the codes and seen if it comes back?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
when the sensor gets grounded it will cause a 32. I would clear it if it comes back on check for shorts on this circuit and even leave he stupid thing in plugged.
http://www.ecklerscorvette.com/corve...1986-1989.html
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
unfortunatly yes it does come back i just replaced my runners and plenum when noticed the temp wire was severed spliced in a new wire and now i have code 32 can there be a vacume line off any were
Engine: Lb9
Transmission: M20
on your ecm pin c15 dk green. if this wire is grounded on start up the code 32 will show. disconnect the egr temp/ diagnostic sensor.
Engine: Lb9
Transmission: M20
in order to acces the sensor will have too pull the plenum
and replace the sensor with a know good one or the link I provided. Gm has discontinued this years ago. Most guys just leave the stupid thing unplugged when it fails.
and replace the sensor with a know good one or the link I provided. Gm has discontinued this years ago. Most guys just leave the stupid thing unplugged when it fails. Trending Topics
Engine: Lb9
Transmission: M20
ambainb
Apr 25, 2016 09:21 PM
mdtoren
Aug 16, 2015 05:45 PM
