Emissions Question (new engine, old car)
Old Jan 13, 2012 | 02:53 PM
snake10566's Avatar
Car: 1990 Trans Am
Engine: Ramjet 350
Transmission: 5 Speed
I have a 1990 trans am 5.0. But it got swapped about 7 years ago to a ramjet 350 5.7. I live in indiana (1 of the 2 counties in the state that has emissions) and I am determined to get her new stickers this year (so i must pass emissions). I tried to get it passed and told them it was a different engine and they blew me off and said they can only test it for what the car says it is. Any ideas on how to get around it? They are testing the dang thing for the emissions of a 5.0 when it is clearly not. Very frustrated.
The ideas i have been given are a po box in a different county, but that sounds like a bad idea in my head.
An engine additive, but i am blowing the hydro carbons and nitrogen way pasted the regular amount. If i remember right, they were around double the amount.
I was suggested a new cat, but i have a buddy that works in a shop and he said it wouldnt do that significant of a job seeing as i already have a performance cat, and its pretty new.
Thanks in advance!
Old Jan 13, 2012 | 07:44 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Emissions Question (new engine, old car)
To be fair, a newer Ramjet 350 should test as well as an old 305; if your numbers are double the nominal values, there's probably something else going on. I'd suggest doing a good tune-up. Be sure to verify your base timing. Check the spark plugs for cleanliness and verify correct gap, or just replace 'em. Look for vacuum leaks as well. If you're running headers in place of the stock exhaust manifolds, you might want to consider using a heated O2 sensor.
Old Jan 13, 2012 | 07:54 PM
snake10566's Avatar
Car: 1990 Trans Am
Engine: Ramjet 350
Hmm, I guess I agree with that. I am running headers so I will look into that. I appreciate the input. Also, nice camaro. Love the accents with the black and white.
Old Feb 19, 2013 | 01:01 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Where in Indiana? I didn't know there were two counties that still test.
Agreed, if its tuned right, it should pass with flying colors.
The Ram jet should be e pretty efficent set up, not sure if you can get into the ecm for tuning.
Old Feb 21, 2013 | 09:23 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Performance cats are 49-state cats. 50-state cats cost more but do work measurably better. HC can be too much fuel, but can also be weak ignition or not enough timing. The RJ350 comes programmed for long-tube 1.625" headers, which you probably aren't using. The RJ350 cam is clean enough, easily. Part of your problem is not having EGR. The '87-legal ZZ4 crate conversion doesn't use EGR either, but that's 87, your 90 has to have it. You could rig up an external EGR, which might be helped by starting with a 75 mm EGR spacer for a same-year Mustang 5.0. That's as close as you're likely to find. IOf you're prepared to spend, converting the RJ to TPI will let it look enough like the original 305, except you're still needing external EGR. However, in this case everything you need already exists. But the same investment should get you a used LB9 to swap in for testing, then replace the RJ after the testing.
Old Feb 21, 2013 | 11:14 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
they would only know its not the right engine if you told them. i know plenty of people with jacked up street cars going through porter county emmisions, and nobody says a thing
ps. 2 original tbi truck cats welded together and then welded into place usually does the trick for me and my buddies, then we drive down the street to the shop and cut them off again til next time. we also know someone that lives in laporte co. and we've used his address before to get plates
Old Feb 21, 2013 | 11:55 AM
wbstearns's Avatar
Car: 01 s10 blazer and 89 bird
Engine: 383 with mystery cam - maybe
Transmission: t56 hopefully
Axle/Gears: 373 geared posi from 2002 z28
hot rod magazine did a 383 in a third gen with emisions testing and with a stock chip and all emisions hardawre hooked up it passed as a 305 so your r.j. should def. be able to pass if you tune it up right and keep a stockish chip in the computer the egr is def one issue if you dont have one but just tinker and test
Old Feb 21, 2013 | 12:05 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I think that's been done twice. Once with iron production non-Vortec heads, and once with early Edelbrock heads. One of them got away with the stock chip by playing with injectors and an adjustable fuel pressure regulator.
Old Feb 21, 2013 | 03:12 PM
snake10566's Avatar
Car: 1990 Trans Am
Engine: Ramjet 350
Northwest Indiana. I believe it is cause we are so close to chicago. And yeah, I thought it was an MEFI 3 setup but it indeed an MEFI 4 setup, so i was thinking maybe the O2 sensor is sitting wrong or not wired correctly.
Old Feb 23, 2013 | 11:02 AM
Axle/Gears: 2.77
It's because of the mills
Posted from Thirdgen.org App for Android
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
