multi port engine lack of power/surge off and on
Old Jan 20, 2012 | 06:00 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
random lack of power accelerating
off and on, while driving
cant figure it out...
is early mid 1990s multi port engine without MAF
and is not a TBI vehicle
there is no engine fault code set in ECM memory other than the normal test 12 code.
the engine(when trying to accelerate and drive it) one second bogs sputters and acts like it is weak on fuel or ignition on all cylinders, it just wont go,,, and then a second later its full power nice smooth and takes off fine all power again.
usually backing off the gas pedal/throttle some will make it clear up and have power back to accelerate fine again, usually.,
things tried and checked:
fuel pressure normal and filter new
02 sensor unplugged
FP regulator unplugged
EGR unplugged
a known good TPS swapped on
removed cleaned the IAC
pcv cleaned is clear good works fine
out of ideas
maybe failing MAP sensor?
CTS?
this one does not have a MAF
its a 1993-1995 MPFI
Old Jan 20, 2012 | 06:32 AM
ex-x-fire's Avatar
Re: multi port engine lack of power/surge off and on
Did you check the fuel pressure while driving it, under a load?
I'd check the grounds, esp. the ecm grounds, might be near the bellhousing or starter.
Old Jan 20, 2012 | 12:07 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
check your tps too.
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
