idle problem. please help!
Old Jan 23, 2012 | 03:35 PM
jh7823's Avatar
Car: 87 camaro iroc-z
Axle/Gears: borg warner 3.27
so i got my car running good but theres still one little problem. it seems that my care is idling too high. i backed off the adjustment screw and its all the way backed off. my timing is set to 6* btdc. any ideas?!
Old Jan 23, 2012 | 03:39 PM
torque_is_good's Avatar
Re: idle problem. please help!
which engine
what idle adjustment screw?
Old Jan 23, 2012 | 03:41 PM
jh7823's Avatar
l98 the screw on the tb that rests against the throttle where the cables attach
Old Jan 24, 2012 | 05:59 AM
jh7823's Avatar
any ideas?
Old Jan 24, 2012 | 06:16 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
That's not an idle adjustment screw. The IAC adjusts the idle speed. My suggestion is that you first make sure that you have no vacuum leaks, then set you base idle and TPS voltage. There are threads that outline the procedure in detail.
Old Jan 24, 2012 | 08:16 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Now that you've backed off that screw you have two problems to fix.
You will have to find the cause of your high idle, and then reset your minimum air rate and TPS.
Old Jan 24, 2012 | 09:31 AM
jh7823's Avatar
How do I go about doing that?
Old Jan 24, 2012 | 11:07 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I would start with the search button and look for minimum air rate adjustment for TPI.
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
383cam
Sep 9, 2015 06:01 AM
