Oil Pressure
Old Mar 26, 2012 | 08:16 AM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Oil Pressure
My cars oil pressure is going crazy, it hardly goes over 30psi and that is only when the engine is on while driving constantly. (freeway) But when I stop and idle, the psi goes to 0 or very close to. Not sure what is causing this, any ideas?
I would assume oil pump but thats just me guessing.
Also, my fuel pump make a really bad whining noise and before I even touch E my car dies from lack of gas. (not sure if the gauge is off) Sometimes the engine will run real rough and just die like its not getting enough fuel. Not sure whats up, if the fuel pump is going or what...
Old Mar 26, 2012 | 09:53 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Oil Pressure
could be a bad sending unit or bad bearings in the motor..
Old Mar 26, 2012 | 11:15 AM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Oil Pressure
An easy check for the oil pressure is to install an aftermarket gauge. I'd be willing to bet your factory gauge or sending unit is not operating correctly.
Old Mar 26, 2012 | 11:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Pressure
Easier and cheaper to just try a new sender.
Old Mar 26, 2012 | 02:27 PM
Re: Oil Pressure
I assume you are talking about the first part of the post (oil pressure)
Where is the sending unit located? And what exactly is it? I assume it is what takes the data from the engine and tells the gauge what to display but I just want to make sure.
Thanks for the reply's.
Old Mar 26, 2012 | 02:30 PM
TTOP350's Avatar
Re: Oil Pressure
its on the driver side rear of the motor above the oil filter.
The oil pump pickup could have fallen off of the pump also..
Old Mar 26, 2012 | 02:31 PM
Re: Oil Pressure
Is this the sender you are talking about?
http://www.partsgeek.com/catalog/199...re_sender.html
And why is one cheaper than the other, I don't see a difference...?
Old Mar 26, 2012 | 03:14 PM
mrrman's Avatar
Re: Oil Pressure
watching thread
Old Mar 26, 2012 | 06:38 PM
Re: Oil Pressure
So the oil pressure will fluctuate up and down while idling and than go to 0, still a problem with the sender.
Old Mar 26, 2012 | 06:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil Pressure
999,999 times in a million, yes.
Old Mar 26, 2012 | 07:32 PM
mrrman's Avatar
Re: Oil Pressure
I find it hard to believe this since I changed my sender and fuel pump out with a new unit and my gauge still reads 0.
Old Mar 26, 2012 | 08:49 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Oil Pressure
Is your motor knocking,is it noisome,because if you don't have oil pressure it's gonna be.It could be your gauges.
Old Mar 26, 2012 | 09:42 PM
mrrman's Avatar
Re: Oil Pressure
My car turns over but doesnt fire. It has spark and on members recommendations I have changed out the following: new fuel pump ( again), sending unit, ECM, coil, new battery, oil pressure sensor) I shot cold start into it and it tries to turn over but doesnt. Checked fuses, relays, couldnt find anything wrong. My cars sat in my garage over the winter and I started it up monthly then all of a sudden it just quit. Cranks over and doesnt fire.
I dont mean to hijack this thread but have tried almost everything I can think of.
Old Mar 26, 2012 | 10:02 PM
Re: Oil Pressure
Car dosen't knock, runs fine. Kinda rough sometimes but i think that was my half fast job at rebuilding the tranny. The exhaust is smooth sounding and no hickups or anything so I'm pretty sure the motor is good just the oil pressure thing.
Old May 30, 2013 | 07:12 PM
Re: Oil Pressure
It was the oil pressure sending unit, it had oil inside of it somehow. Thanks
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
