Where is the fuel tank for a 92 bird?
Old Apr 13, 2012 | 05:23 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Old Apr 13, 2012 | 05:33 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Where is the fuel tank for a 92 bird?
In the rear, like all cars.....
Old Apr 13, 2012 | 05:52 PM
Engine: V8 305
lol...i know that... i jsut wasn't sure on what side or if it is in the middle...i think i may have a fuel pump problem.
Old Apr 13, 2012 | 06:05 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
It's above the rear axle. You need to loosen and pretty much remove the muffler and exhaust from the catalytic converter back, drop the axle by detaching the shocks from the axle. Then you can wrestle the tank out. Before you go there, be sure you have power and ground at the pump. There is a connector just above and in front of the tank that carries the power and ground to the pump. Test there. Note that the pump only runs for two seconds when the key is turned on, then only comes back on when the engine is cranking. If you have power at the pump and no pressure at the test port, which is on the passenger side fuel rail of the TPI engine, listen at the filler neck with the cap off for the hum of the pump. Also, before dropping the tank, be sure the fuel filter which in front of the left rear tire, is not clogged.
Old Apr 13, 2012 | 06:28 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
In exactly the same spot as every single 1982-2002 Camaro & Firebird. Behind the gas door, all the way (mostly) across, above the rear axle. All it takes is for you to actually look. Follow the tube from the gas door across & you'll find it. If you can't? Sorry, but you shouldn't be working on it.
Old Apr 14, 2012 | 10:37 PM
Engine: V8 305
thanx...i ended up finding a hole cut above the tank...the previous owner had pump problems before.
Old Apr 14, 2012 | 10:39 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Oh, no. Here we go!
Old Apr 14, 2012 | 10:46 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Originally Posted by watajob
Oh, no. Here we go!
Old Apr 14, 2012 | 10:53 PM
Car: GTA
Not an uncommon thing & something the factory shoulda done in the first place since that are is ZERO to do with the structural integrity of the body/chassis and make pump access much easier if the lines have disconnects there.
Old Apr 18, 2012 | 06:23 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Lol. I guess I've made my feelings about fuel pump hatches well enough known on this forum. Honestly though, Blackened Bird makes a good point. I get pretty tired of pulling fuel tanks on cars day after day at work. The best car designers are thoughtful enough to provide a means by which to access the pump without dropping the tank. I suppose if it is correctly done, it is not a bad modification to make. The trouble I have with the ones Ive seen done is that they appear to have been done in a hurry with little thought to the finished result. If someone were to make a clean opening and finish it with a nicely made cover that actually sealed to the floor pan and made clean safe connections at the fuel lines, I guess I really couldn't find fault with that.
As for myself, since my engine is a beast anyway and I got tired of the intank pump sucking air on a hard corner with less than a 1/3 tank of fuel, I just put an AN 12 pick up line into the tank, after pulling the tank from the car. Then I plumbed in a Holley Blue Race pump drawing from the tank and feeding a reservoir at the front of the car through AN10 line. An Aeromotive 70GPH pump draws from the reservoir to feed the rails. So now I have no intank pump to worry about and I can corner as hard as I want with no fuel dropout.
Old Apr 25, 2012 | 01:57 PM
Engine: V8 305
ya...the one in mine was also in a HURRY to get done...not professional at all...dissapointing... problem still persists though....now i gotta find the fuel pump relay.
Old Apr 25, 2012 | 03:26 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Woah! Now slow down there a minute speedy. I thought you were going to verify power and ground at the pump before you swapped it. It is time now to start diagnosis before any more good parts get swapped out. Do you have a 12V test light? They're cheap to buy and you can use it to verify power and ground at the pump then work your way back to the relay and on to the ECM/FP fuse. It is fair to jumper the relay to test the power and ground circuits to the pump but be careful not to short something out.
Old Apr 25, 2012 | 08:58 PM
Engine: V8 305
i put the car on a scantool and it read the codes on the car and it was the relay code...i bought a new fuel pump relay but i am not sure where its located on a tbi engine.
Old Apr 26, 2012 | 11:13 AM
TPIscreamer's Avatar
Car: 1989 Camaro RS, '85 firebird
Engine: 305 TBI, 350 TPI
Transmission: built th-700r4,T-5
Axle/Gears: 3.23 Posi, 3.55 posi
the fuel pump relay is on the firewall on the driver's side, just above the brake booster, there should be two big relays there, i can't remember which one is the radiator fan and which is the fuel pump
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
