Gasoline 355sbc
Old Apr 13, 2012 | 09:49 PM
84TransAmNY's Avatar
Car: 2001 GMC Sonoma 4.3/ 84 Trans Am
Engine: SBC 355
Transmission: 89 World Class Borg T5
Axle/Gears: 3.42 10 bolt
Gasoline 355sbc
So in about a 2 months my car should be on the road. The engine is a completely rebuilt Sbc 350 bored .30 over. Basically every thing is new except for the connecting rods, crank and starter. A guy at work was telling me he was having major issues running premium gas in his fastback 428 mustang. So he switched to delta sonic 100 octane and it now runs like a dream.
My question is what should I run in my car? I can give more specs on engine parts if that will help. I don't mind paying a little more for the gas since I will only be driving the car on real nice days a few days a week. I live in NY so if you could recommend any places besides delta sonic that has good high octane let me know as well. I have never had a 350 not sure on what my MPG will be. Probably 12-15 right?
Old Apr 14, 2012 | 08:24 AM
ex-x-fire's Avatar
Re: Gasoline 355sbc
You have to take into account the compression ratio, ignition curve, egr valve, & modern cylinder heads. The 428 is old tech compared to something like a sbc w/ vortec heads.
Old Apr 14, 2012 | 12:48 PM
Engine: SBC 355
Re: Gasoline 355sbc
I don't have egr on mine or vortec heads. I won't have to have any smog equipment on mine. His compression is 11:1 or something like that. Mine is going to be around 9-9.5:1 according to my dads buddy. I have cast iron dart s/s heads and edelbrock rpm performer with a rochester 4 barrel 750cfm. Mild cam, hydraulic lifters, manley valves and forged mahle pistons.
Old Apr 14, 2012 | 12:51 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Gasoline 355sbc
With that compression ratio you will be fine on regular pump gas.
Old Apr 14, 2012 | 12:55 PM
Engine: SBC 355
Re: Gasoline 355sbc
oh okay... what you think I will be getting for mpg?
Old Apr 14, 2012 | 01:10 PM
85T/A350's Avatar
Engine: 350 Vortec
Re: Gasoline 355sbc
12-15 is probably a good guess. Do a search for mpg and see what other people with similar setups are getting.
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Gasoline 355sbc
Need a LOT more specs. A long way off from giving ANY estimate on what we know now.
Carb? FI.....TBI/TPI/Sequential conversion? Gears? Auto/Manual? etc./etc./etc.
Old Apr 14, 2012 | 05:16 PM
Engine: SBC 355
Re: Gasoline 355sbc
750 rochester 4 barrel, comp cams got .454 lift, 3.42 gears, t-5 manual anything else..heads are only 72 cc, edelbrock performer rpm.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Justin92GTA
Aug 27, 2015 11:16 PM
84zeddd
Oct 24, 2002 11:28 AM
Sciguyjim
Jul 8, 2002 05:17 PM
84zeddd
Carburetors
Jan 16, 2002 01:19 AM
