New cam with lifters, springs and valves. But how to buy?
Old May 7, 2012 | 09:24 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
I have a camaro with a 305 in it. One of my valve springs cracked so I figure ill just upgrade my whole valve train. Question tho, I want to buy a new cam, springs, valves, lifters, and rockers. But I have noooo clue on what kind I should buy.
Some say max lift .476 or something like that. I don know what this means. Help a little? Thx
Old May 7, 2012 | 09:54 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: New cam with lifters, springs and valves. But how to buy?
You have to make sure that the springs will take the llift of the cam... If you order the GM Hot Cam kit, you will have all of the parts necessary to make the valve train work correctly
MoJoe
Sep 24, 2015 09:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
