Visual diff. 305 vs. 350 tpi
Old May 9, 2012 | 09:22 PM
Gsterz's Avatar
I know there are super old questions about this but i was wondering BESIDES the vin number, someone is telling me that their 86 iroc has a 350 from a vette (i see it's a tpi) but it was originally a 305.
I wanna know if it's an l98 or a the 305 and don't know if he knows what he is talking about. I am thinking about getting it. How can I tell if it's a 350 or 305?
He said it's pushing about 270hp with magna flow exhaust. Is that possible with the l98 with pretty much stock setut?
Old May 9, 2012 | 09:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Visual diff. 305 vs. 350 tpi
Checking numbers is the only way. Just looking at it, a 305 will look just like a 350.
Old May 9, 2012 | 10:07 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If it's a TPI from a Corvette, it will be a 350. I think all the Corvette's were alumiunum heads, so that should be easy enough to check.
Old May 9, 2012 | 10:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Lots of aluminum heads have been put on 305s over the years. And there are more motors "out of a Corvette" sold than there have been Corvettes made.
Casting numbers are the only way to know.
Old May 9, 2012 | 10:39 PM
Gsterz's Avatar
Where would the casting numbers be located?
Old May 9, 2012 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Top surface of the block at the back behind the heads.
Old May 9, 2012 | 11:01 PM
Gsterz's Avatar
Is it difficult to reach/look at? Will it just be exposed (no covers or anything). Thanks for all the help so far guys
Old May 9, 2012 | 11:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No covers or anything on it, but it won't be terribly easy to get to, unfortunately.
Old May 10, 2012 | 12:19 AM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Many times the numbers are covered in a layer of grime. Take a wire brush and a small mirror and you should be able to get a decent look.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
