Rebuilding oil pump
Old May 16, 2012 | 05:31 AM
Jcaldwell3607's Avatar
Rebuilding oil pump
I just want to can I rebuild my oil pump while it's still bolted to the block and how would I do it
Old May 16, 2012 | 07:12 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Rebuilding oil pump
OK Jcaldwell oil pumps are not that exspensive to buy brand new, what motor do you have and what is the problem with the oil pump.
Old May 16, 2012 | 07:54 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
not really any rebuilbing that can be done with the oil
pump-you can take it apart and check for wear though;
look for scratching and gouging of the housing where
the gears turn and the drive gear shaft and housing
bushing for wear and excess clearance.All the above
wear conditions are likely to be found if a lot of miles on
pump.Racers will often take apart a new pump and
check clearances,port/radius a few areas,add balance
grooves to cover plate etc.
Old May 16, 2012 | 09:10 AM
Well I a 89 350 and the bolts to the oil pump run down form the main bearing cap into the oil pump and I cant get the main bearing off because the oil sits under one of the main bearing bolts and you can rebuild them nothing to it just wanted to know if u could do it while it's still on the block
Old May 16, 2012 | 09:52 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Is this making any good sense to anyone else? Un-bolt the pump from the rear main cap, it's no challenge. Then do whatever you like, then torque a pump back in position. Simple.
Old May 16, 2012 | 11:55 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Please, put a few stop signs in your typing. It makes it a lot easier to read. thanx!
Old May 16, 2012 | 12:41 PM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
better off just replacing it. Trust me
Old May 16, 2012 | 01:14 PM
I understand to replace it. But I just wanna know if it's possible to rebuild while still being bolted to the block that's all I wanna know.
Old May 16, 2012 | 01:21 PM
TTOP350's Avatar
Yes you can. Unless you want to change the clearances..
Old May 16, 2012 | 02:34 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Hmm? For one thing, there are only two moving parts to the pump. These are the gears that make up the pump. I guess there are three if you include the relief valve. They are not available for replacement since they are a fine tolerance part and are sized for each pump. You were already told that the key to the oil pump is the clearance between the gears and the thrust surfaces of the pump case. There is nothing you can do to correct a worn pump but to replace it. Also, if you do disassemble the pump be sure to align the marks on the gears during reassembly since they are balanced together.
I have never heard of rebuilding a Chevrolet V8 oil pump and I've been in this industry a long long time. Just replace it and torque the bolt to 65ft lbs. The best oil pumps are Melling. They make an excellent high volume pump for the small block chevy that uses a bolt on, 3/4" pick up tube versus the stock press in 5/8" tube. Are you having trouble getting the bolt loose? You need a long 1/2 drive breaker handle and a 5/8" socket or a big **s 1/2 drive air impact to do it.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
