INSTANT car start when cold
Old May 23, 2012 | 10:57 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Hi everyone,
My car seems to have this strange starting problem. When cold, if i go to start it, LITERALLY as soon as i go to start it it starts, most times even if i blip it for just a second it starts so fast i grind the gear and it usually will stall instantly. After that, i start it up and it starts fine. I dont understand what would cause this, i have only checked TPS and its perfect, right on the dot. Im not even sure what to check next! I appreciate all help.
Old May 24, 2012 | 12:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: INSTANT car start when cold
Congratulations
That is what everyone else is trying to achieve; the perfect , no crank start
Read the many complaints from guys who's engines crank over too long before firing up
Old May 24, 2012 | 12:18 PM
Black88Z's Avatar
Lol no, its not that. It starts up so fast that it stalls itself out. It almost seems like it has so much fuel pressure that when it starts it dumps it all in the cyls', so its starts for a second but floods it pretty much instantly. I dont really know how to describe it, thats what makes it even harder to diagnose.
Old May 24, 2012 | 07:52 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So your header should be it stalls as soon as it fires up?
Do you get black smoke , fuel smell from it being too rich?
Could also stall from no fuel
Could just as easily be only firing up on the fuel from the cold start injector and then stalling from lack of fuel from the main injectors
What is your fuel pressure?
Old May 24, 2012 | 10:24 PM
Black88Z's Avatar
Well it doesnt always stall on the first try, but it does always start fast.
I get no smell of it being too rich.
I have ohmed the injectors cold and warm and they were all perfect.
I have a brand new, like 3 month old OEM fuel pump, tank, sending unit, and fuel filter. The pressure was perfect when it was checked a few monthes ago.
I had kinda forgot about that 9th injector, could i try unplugging it to see what difference it makes? Or is there a better way to check for the problem?
Old May 25, 2012 | 07:41 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Could be leaking injectors which would let fuel into the cylinder while car was shut off.
Old May 25, 2012 | 04:52 PM
Black88Z's Avatar
I thought about that, but i dont think its that. If it was, it would probably be that way even when warm/hot, and its not.
Is there a way to check for leaky inj's? Im not sure if ohming them will tell if they leak or not.
How should I check the 9th injector? Ive never ohmed it, I guess ill try that and see what it says.
Old May 25, 2012 | 06:03 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
I figured out mine were leaking when I had fuel in my runners heading up to the plentum.
Old May 25, 2012 | 08:29 PM
Black88Z's Avatar
Well I ohmed the 9th injector like you would do the others, and it said 4.5 while cold. I dont know if thats the right way to check it, or if the 9th inj is supposed to be that low, but thats what it said. I didnt get to check it hot.
Is it supposed to be that low, or is it supposed to be about 16-20 ish like the rest?
Old May 25, 2012 | 10:41 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Did you try starting it with the 9th injector unpluged just to see if there's a difference?
Old May 26, 2012 | 09:17 AM
Black88Z's Avatar
I havent done that yet but had planned to give it a try. Will that throw a code though? And even if its unplugged the injector can still leak right?
Old May 26, 2012 | 10:52 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No
CSI has no connection to the computer;
is just a injector operated by a standalone electrical switch that only gets power when the engine is being cranked over
Correct
Old May 27, 2012 | 10:25 PM
Black88Z's Avatar
Ok, ill give this a try tomorrow. Is the 9th injector only supposed to be at 4.5 ohms though?
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
drathaar907
Aug 6, 2015 04:20 PM
