Voltage gauge reading at 18 volts!
Car: 1990 IROC
Ok here we go... I bought my 1990 IROC almost a year ago, and it's completely stock. The. Volt meter pegs out in the red zone at 18 volts, and it will move back and forth when the blinkers are being used. What's is causing my voltage to be this high. I never really cared before, but I'm gonna start running out of town a lot and do not want to get stranded. And yes it's been running like this the whole year I'm been driving it, and it's my everyday driver. Bad stock volt gauge? I would I test the alternator?
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Voltage gauge reading at 18 volts!
Get a volt meter a measure across the battery while it is running and see if it really is 18 volts. If the volt meter reads 14 then the gauge is bad. If it truly is 18v then the alternator is bad. If you leave it that way many bad things can happen.
Car: 1990 IROC
So I put it the voltmeter leads on the negative and positive on the battery.
Car: 1990 IROC
I just did this, voltmeter showed 25.5!!! Is this even possible?
I've never seen a car go that high, but you better stop driving it until you can replace the alternator. Peak operational voltage for car electronics is somewhere around 14-16 volts I think? Correct me if I'm wrong, but, even if I am, that's an absurd amount of voltage
Car: 85 Trans Am
Change your alternator. The internal regulator is most likely shot of it it doing that. I'm truly surprised you haven't fried every electronic in the car. I'm sure you headlights are very bright at that voltage! And our right most 12v systems peak out at 16V.
Car: 1990 IROC
So is any wiring of the car out of the question? So this is a inside the alternator deal?
Car: 85 Trans Am
Correct. Since around 73 all GM delco alternators are internally regulated.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if the voltmeter you used to check battery voltage is a
battery operated"multimeter"make sure the battery is
not weak in the multimeter-many of those give false
reading if battery weak...An actual 25.5 volts should
have boiled the battery dry,burnt out any light bulbs
that were on,burnt out the fuel pump,and fried most
electronics...Bulbs ,motors,electronics will withstand
18v for a while.
18v for a while.
Car: 1990 IROC
18v for a while.
18v for a while.
Car: 1990 IROC
Ok here is an update. Finally got the alternator off, took to autozone they said it was a good alternator. Wrenched up the alternator again, started my car, volt gauge was at 13 or 14 volts! Went to close the hood, notice I didn't plug up the 2 wires in male lead to the connection on the alternator, when I plug male end up, the voltage jumps back to 18 volts! So what's up with those 2 wires?
Car: '82 z28
Engine: L83 5.7
actually sounds like everything might be ok except
instrument panel voltmeter might be reading a little
high-with the wires off the alternator,the alternator was
not putting out any voltage and gauge was showing
battery voltage;normally 12.5-13v,once you reconnected
the wires to the alternator it was working again.
If you measure over 15v at the battery with a known
accurate voltmeter,your alternator is putting out too
much voltage.
much voltage.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
