View Poll Results: Is a 1987 2.8 v6 good if had small mods
Yes
33.33%
No
33.33%
Yes but has downfalls
0%
No just keep it stock
33.33%
Voters: 3. You may not vote on this poll
1987 firebird problem HELP!!!
Old Jun 15, 2012 | 04:13 AM
Brynpowers's Avatar
Car: 1987 Firebird
Engine: 2.8l (173cid)
Ok a brief history of the car:bought brand new in 1987 it's a 2.8l v6 mpfi.
Problem sat for 3 years because fuel pump had went out and did not have money to fix so we finely pulled the gas tank and a friend of mine said to clean the gas tank out with muratic acid so we did because there was rust in the tank and it cleaned it out good and we did slosh gas in there after we put the acid in then we put the new fuel pump in and it ran but not real well we could not give it gas(like all the way by just flooring it) so we just slowly reved it and sometimes it would die so we bought a new battery and put it on started first try no problem then drove it down the road and back all is fine then the battery started dieing do we bought a new alternator and put it on now the fuel pump does not come on we also replaced all vacuum hoses and check all the fluids. They all checked to be okay.
We are not sure what happend any replies would be greatly appreciated. Thanks.
Old Jun 15, 2012 | 04:30 AM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
Re: 1987 firebird problem HELP!!!
You put a new alt that put out how many amps? Probably fried the pump due to it being not used in so long then all of a sudden alot of amps and voltage came in so it burnt also check fuses and relays
Old Jun 15, 2012 | 04:53 AM
Brynpowers's Avatar
Car: 1987 Firebird
We took the alternator and had a new one just like it so it was same amps and voltage. We also checked the fuses..we changed the pump by out selfs but now we are thinking about taking it somewhere and have a
New gas tank and fuel pump put in..I just want to drive my car I love driving it.
Old Jun 15, 2012 | 05:19 AM
Engine: LT-1
You put a new pump? with same wiring harness?
Old Jun 15, 2012 | 05:22 AM
Engine: LT-1
Fuel pump fuse is here. It is located right next to the battery probably mounted on the fender. It looks like a clip going into a ground but its really the fuel pump fuse. I'm sure it could be wired inline also, its easy to spot. 20 amp fuse. Also check your under-drivers-dash fuse panel for appropriate fuses and conductivity. The fuse that also should be checked is on the top row, second from the left. That particular fuse is a 10 amp.
SOURCES: https://www.thirdgen.org/forums/elec...ula-350-a.html Thanks to Iroc_youroll for this information.
Old Jun 15, 2012 | 05:23 AM
Engine: LT-1
passenger side fender
Old Jun 15, 2012 | 06:04 AM
Brynpowers's Avatar
Car: 1987 Firebird
yes a new pump and same wiring and everything.. i will look there and see i know there are fuses on the drivers side sown under the dash..
Old Jun 15, 2012 | 06:21 AM
Engine: LT-1
yea is your fuse panel under dash labeled? and visible
Old Jun 15, 2012 | 06:32 AM
Brynpowers's Avatar
Car: 1987 Firebird
yea lol but the lables are not able to be read so what do i do??
Old Jun 15, 2012 | 07:55 AM
Engine: LT-1
ill get you a diagram asap.
Old Jun 15, 2012 | 07:59 AM
Engine: LT-1
Old Jun 15, 2012 | 08:01 AM
Engine: LT-1
Engine: LT-1
HEllo it appears as the image doesnt show just right click on the empty white area and click View Image and you will see it.
Old Jun 15, 2012 | 08:21 AM
Brynpowers's Avatar
Car: 1987 Firebird
thank you tons!!!!!realy appriciate it!
Old Jun 15, 2012 | 08:28 AM
Brynpowers's Avatar
Car: 1987 Firebird
can you send me the link to the picture i still can not see it i dont know why..?
Old Jun 16, 2012 | 03:18 PM
Engine: LT-1
Here. https://www.thirdgen.org/forums/atta...rs-fusebox.png
jhawkeye
May 25, 2022 06:33 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Infested
May 22, 2018 11:56 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
jahblah
Aug 12, 2015 05:54 PM
