piston rings or valves seals
Old Jun 17, 2012 | 09:27 PM
oramac91's Avatar
91 camaro No compression in number 1.(or very low) wont blow your finger out.Does not smoke.runs ok.My question is how do i check to see if its the rings or valves.the 1 plug had burnet oil on it?number 1 is still getting spark after i cleaned it and fired it back up.I heard you can check with paper on the tail pipe or with a vaclum gauge.and help would be greatly appereciated,thank you!!!
Old Jun 17, 2012 | 10:02 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: piston rings or valves seals
Try a few squirts of engine oil thru the spark plug hole and recheck. If the compression comes up, it's most likely rings. If there is no change in compression, it's most like;y the valves.
If it points to the valves, you now need to make sure that valves are opening and closing. Pull the valve cover on that head and check for broken/bent hardware.
Old Jun 18, 2012 | 10:26 AM
oramac91's Avatar
Ty i try that.Iam thinking who ever put this motor together was a dumb ***.I have had to replace just about everything on it.It had no gaskets on it.(top end above heads)
Old Jun 19, 2012 | 03:07 PM
oramac91's Avatar
I did oil test, says valves , could it be the head gasket,Everthing looks good under the valve cover?It did over heat.......Ty jason
Old Jun 19, 2012 | 03:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Could be a burnt valve too. Either way, it sounds like the head has to come off.
Old Jun 19, 2012 | 05:27 PM
oramac91's Avatar
ya .sucks haveing to all that stuff off.But it must be done!!!Not looking ford to this rip down.Done it before,Thx. I let you know how it turns out.
Old Jun 24, 2012 | 12:09 PM
oramac91's Avatar
Took left side head off .1,3,5 small valvess are brown colored.Pistons say 345 std.Is that stock?And head gasket does not look blowen.I will post pic of heads and gasket tomorrow.
Old Jun 25, 2012 | 02:02 PM
oramac91's Avatar
The number 1 Exhaust valve was warped.
Attached Thumbnails piston rings or valves seals-dsc00537.jpg   piston rings or valves seals-dsc00539.jpg
Magman
Sep 13, 2015 08:43 AM
gixxer92
Sep 1, 2015 04:32 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
