Knocking/smacking noise? Not from inside engine tho
Old Jun 30, 2012 | 11:43 AM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
When I start my 84 camaro it runs fine but it makes this sound like something is hitting something else. It's not from inside the engine it's a differnt noise than that. It seems to be coming from the starter or flywheel. Any ideals on wat it can b?
Old Jun 30, 2012 | 12:06 PM
Re: Knocking/smacking noise? Not from inside engine tho
Cracked flex plate
Old Jun 30, 2012 | 12:27 PM
Jfinnkma91's Avatar
No. The flex plate is fine. Already checked that
Old Jun 30, 2012 | 01:16 PM
How?
Old Jun 30, 2012 | 01:25 PM
Jfinnkma91's Avatar
I had the engine and tranny out. The flex plate was fine from what I could tell. Not cracks or Anything. I put it all back together and I hear that damn noise
Old Jun 30, 2012 | 01:58 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
There was a previous thread where a guy had a similar noise, and it turned out to be a loose starter. Check this if you haven't.
Old Jun 30, 2012 | 02:11 PM
Jfinnkma91's Avatar
Come to think of it I kinda hurried up and threw the starter on. It might very well be that.
Old Jun 30, 2012 | 11:46 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
also check the plastic cover the covers the torque converter/flexplate. I put that on wrong once and it sounded like you're describing.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
