Shattered Spark Plug, What did it break? Please Help!
Old Jul 11, 2012 | 06:47 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
Engine: some sort of small block
Hey Guys, I just completed a carb swap on my 87 camaro with a 305. It seemed to be going great until I heard a very loud ticking. At first I thought it was detonation from incorrect timing, but after pulling the plugs i found out cylinder #7's was DESTROYED! I replaced it with a new one hoping for the best, but it still knocks/ticks and barely idles at all.
After pulling the valve cover the intake valve on cylinder 7 had a ton of free play in it, it moved up and down probably a quarter inch. The push rod is not bent either, so my question is, what broke? Is it the lifter, valve itself, or something more serious? I don't know where to go from here, any help is much appreciated guys! Thanks!
Old Jul 11, 2012 | 07:00 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: Shattered Spark Plug, What did it break? Please Help!
if you just did a carb swap only why would a valve drop or lifter collapse?
did you drop somethin down the intake manifold during the swap?
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
What broke from the plug?
If the electrode broke off, it's going to bounce around & cause problems with the piston, combustion chamber, and valves.
Checke the valve springs for breakage, same for the rocker(s). Check for cracked valve stems, or even broken valve(s).
If that's not the prob, could be collapsed lifter(s) or flat cam lobe(s), stripped // damaged, or lifting rocker studs.
Check plug wires for arcing, burnt areas. A burnt plug wire will make a tapping sound as it grounds to exhaust. Check for exhaust leaks around the head // exhaust manifold // headers. That will cause ticking sounds also.
Old Jul 11, 2012 | 10:50 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
Thanks for the replies, well no damage to the rockers or valve springs. The electrode could have broken off into the cylinder, the plug was pretty much destroyed when i took it out.
I put the engine at tdc and lashed the #7 intake valve. When i turn the engine over by hand it still opens and closes, goes up and down. Does this rule out a broken lifter? Or even a broken valve? I'm considering starting up the engine again to see if just lashing it back down will help
Old Jul 12, 2012 | 02:36 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
If you can move the valve by hand, you've GOT to have some damage to what holds the valve on it's seat. Ie broken spring or retainer, valve tip, or locks popped off.
If the valve's dropped, and been been hammered up and down by the piston, theres probably some unpleasant surprise waiting for you in the bore. Like the chunk of valve head or piston that broke the spark plug.
Old Jul 12, 2012 | 03:06 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
With the just the plug I was saying to myself that it would be a good idea to pull the head. With the valve issue also it seems more imperative to do so. If you have a real problem you will find it by pulling the head.
Better to find out now instead of later. Could mean a new motor then. It might be nothing but could be something wrong now and cheaper to fix it now as compared to later.
Old Jul 12, 2012 | 01:54 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Best to tear it down now. If it continues to run you risk debris getting into other cyls and causing more damage. I had a chunk of exhaust valve break off on a chevy 350 in my boat. I ran it till it died trying to get back to the dock. Pieces of the valve wound up in 3 additional cyls.
I'd also remove and check the "new" carb carefully. May find the little screws that hold the throttle plates to the throttle shaft are missing..
Old Jul 12, 2012 | 07:06 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
Thanks for all the replies, its always appreciated! Ok, looks like its time to tear the head off and see what's going on, hopefully its not too expensive to fix
Old Jul 12, 2012 | 08:11 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Pull your new no 7 plug again - has it too sustained damage? Post up pics if you can, we all love some good carnage!
Old Jul 12, 2012 | 09:04 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
Yep, destroyed again. When i turn the engine over by hand i can feel a TON of resistance when that cylinder is at tdc. makes me think either a valve or something is physically breaking the plug.
Attached Thumbnails Shattered Spark Plug, What did it break? Please Help!-plug.jpg
Old Jul 12, 2012 | 10:51 PM
Car: '87 Camaro
Yup
You have some debris from something in there!
Don't try to start it again.
Pullmthe head.
Hopefully you caught it before the piston cracked or valves got hammered, or the cylinder wall got gouged!!! EEK!!
evilstuie
Feb 28, 2016 03:33 PM
86CamaroDan
Sep 29, 2015 10:08 PM
LittleFranks
Sep 17, 2015 12:22 PM
Gunsbee
Sep 7, 2015 07:10 PM
