91 z28 wont start
Car: 91 Z28
Engine: 305 tpi
Axle/Gears: posi
91 z28 wont start
i was driving for about 30 minutes came home for 10 and went to leave again car stalled at end of driveway (never stalled before) recovered, then made it 100 yards and died, pushed it back, thought it was tranny at first scratched that, thought it was sabotaged, no gas but meter was bad, none of those things.
we were trying to get it started yesterday, it starts with starting fluid but you have to keep revving it or it will die, the fuel pump was making a higher pitch noise than normal then today we were going at it and it wont prime at all. i already checked fuse and it was fine but i changed it anyways.
getting paid Thursday lets get back on the road!!!
Car: 91 Z28
Engine: 305 tpi
Axle/Gears: posi
Re: 91 z28 wont start
right, im waiting on this guy with the auto zone tool that tells you the codes and what not but hes being extremely unreliable hes blown me off on both my days off.
its also not MAF sensor, i mean it could be but when we were keeping it alive revving it my dad unplugged the MAF and it cut off immediately so it seems to still be working.
FUEL PUMP IS NOT PRIMING AND CAR WONT STAY ON
Car: 1987 Camaro IROC-Z
Engine: LB9
you know you can check codes with a paperclip right?
rent a fuel pressure test gauge and check what you are getting for fuel pressure,
Car: 91 Z28
Engine: 305 tpi
Axle/Gears: posi
i did not know that and i haven't the slightest how it would work.
i'm going to rent that tomorrow and check my pressure.
Car: 91 Z28
Engine: 305 tpi
Axle/Gears: posi
tried the relay for fuel pump put the fan one in that was replaced like a month ago and no change.
starting to look like the pump is done for
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
Car: 91 Z28
Engine: 305 tpi
Axle/Gears: posi
did the paperclip thing and it has code 12: no reference pulses to ecm
that paperclip thing is a great thing to know.
so theirs no codes referring to my fuel pump then its the ecm?
what should i be replacing here?
Car: 91 Z28
Engine: 305 tpi
Axle/Gears: posi
got a fuel pump on hold for 55 at autozone gonna grab it tommorow and replace the old one. even if it doesnt fix the problem im sure its well past its miles
