Help me get this starter out!
Old Aug 24, 2012 | 04:44 PM
Blue91Z28's Avatar
I have a "stock" 1991 Z-28 with a 5.7 TPI. I am replacing the starter, which broke the nose cone??, and can not seem to find a way to get it out of the car. It is unbolted but how do I get it past everything that is in the way. It will not go up. It will not go down. How is this done?
Thanks!
Old Aug 24, 2012 | 07:55 PM
Re: Help me get this starter out!
How is this done?
With extreme ease.
Rotate the brush end up (nose down), solenoid toward the front of the car. Make sure your face is not right under it, because it will fall out.
Installation is the reverse of removal.
Old Aug 24, 2012 | 09:07 PM
Blue91Z28's Avatar
Thanks. If it can be done them I will figure it out. It looks like the exhaust pipe needs to come down for it to fit.
Old Aug 24, 2012 | 09:18 PM
Damon's Avatar
It does a very effective job of giving that illusion, doesn't it?
It'll come out just like Sofa said. It's all in how you orient it for the drop. Then it's like "look out below!" Plunk, it's out.
Old Aug 24, 2012 | 09:23 PM
Blue91Z28's Avatar
You guys make it sound so easy. I am looking forward to the big drop.
Old Aug 24, 2012 | 10:25 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Let it drop down and lay between the control arm, block and exhaust. Lower the car down on the ground. When the control arm compresses up, the starter will fall down...
Old Aug 26, 2012 | 08:45 PM
Blue91Z28's Avatar
Thanks! You guys are great. I got the broken starter out, installed the new starter, only to find that the parts guy sold me a starter for a large flywheel. SO I removed the wrong one and installed the correct one. I am very good at changing the starter now. Every thing is working just fine finally. Thank you so much for the info on how to change it. Now I know how all to well.
Old Aug 26, 2012 | 09:00 PM
Damon's Avatar
Cool. Glad to help. Good job.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
