Front assembly issues
Old Aug 29, 2012 | 03:12 PM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
So I finally got my heads back from the shop (been since september last year when i took them in) and as im putting the car back togeather i have ran into an issue....I completely forget how to bolt all these brackets up and where they go I have plenty of pictures sadly i cant tell exactly where everything goes so just if anyones able to give me some quick help it would be appriciated but if not...
Attached Thumbnails Front assembly issues-1camaro.jpg   Front assembly issues-2camaro.jpg   Front assembly issues-camaro.jpg
Old Aug 29, 2012 | 05:30 PM
Car: 86 z28
Engine: 305ish
Re: Front assembly issues
Most apologies a blindfolded monkey could have figured it out
Old Aug 29, 2012 | 06:18 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Those monkeys are pretty smart.
Old Sep 8, 2012 | 02:35 PM
Car: 86 z28
Engine: 305ish
youd be surprised now i just need a few of them to figure out how to get these longtubes to fit
Old Sep 8, 2012 | 02:38 PM
Edwardgp's Avatar
Engine: 454-350
You might go out there and see them jacking your motor up a little. Hope they remembered to remove the distributor cap.
Old Sep 9, 2012 | 08:18 AM
https://www.thirdgen.org/forums/engi...cket-help.html
Old Sep 9, 2012 | 08:35 AM
Car: 86 z28
Engine: 305ish
thankyou sofa O.o although it seems i have my power steering mounted in the entirely wrong place also I just put my distributor in do I really need to jack the motor up to get them in there right well or do the monkeys really need to jack up the motor and if so where should i jack it up from wait... i could search the forum for that info if i wasnt lazy so since sofa gave me most of the info i need i suppose i could look for that piece on my own
Old Sep 9, 2012 | 08:39 AM
Edwardgp's Avatar
Engine: 454-350
Let us know how you are doing bro, check with you later.
Old Sep 10, 2012 | 09:02 AM
Car: 86 z28
Engine: 305ish
ill be sure to put more pics up and a video or somthing when its running so everyone can tell me what i did wrong when adjusting my valves =]
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
