tpi 350 oil coolong setup
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
hi i want to have this set up on my camaro whne i swap to my 350 tpi can i get pix of the hole setup
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: tpi 350 oil coolong setup
Very difficult to get a pic of an installed setup, but it basically consists of 2 pieces. The "sandwich between the oil filter & the block & the tubes running from it to the coolant hoses.
I know https://www.thirdgen.org/forums/member.php?u=40809 has a brand new reproduction tube piece & a used sandwich adapter for sale, if your looking for a setup.
(sandwich piece is in the cardboard box)
Car: 92 camaro rs
Engine: 3.4v6 sc
ok so it sends coolant throw it ??? i have a late modle 5.7 block out of a suberben im using it has a oil cooler on it looks like it sends it up fron and the oil go's throw the lines no coolant
Car: GTA
Yep. Oil goes from the block through the sandwich, into the filter. Out of the filter, back through the sandwich & into the block.
Coolent runs from the radiator, through those lines to the sandwich, loops through & goes back to the radiator.
My balancer came apart a few years ago. The outer ring slid back & ate through the tube causing a coolant leak. I pull the tubes are, capped off the coolant lines near the radiator but left the sandwich in place. Been that way a couple years now. Doesn't hurt anything by not having it working. Makes it the same as 99% of all other SBCs made without oil coolers.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
If you want an oil cooler, ditch the chocolate milkshake maker for something like this:
Car: 92 camaro rs
Engine: 3.4v6 sc
well the block is out of a truck so its a HD BLOCK 4 BOLT MAINS AND ALL THAT its got the subrben cooler
GM used different style coolers in different applications. The 3rd gen F-bodies ran coolant through a "sandwich" cooler where the oil itself ran straight through it. I.e. they brought the coolant to the oil.
On trucks (like my 1990 454 SS) the "sandwich" looked similar but it actually sent the OIL to an external cooler built into the driver's side radiator end tank. Those systems were better at cooling the oil, quite frankly, but they were HELLACIOUS for oil leaks. The connectors were finnicky and the seals prone to failure. Most "real world" beater trucks that used this system you'll find it has been defeated and removed for that reason.
The 3rd gen F-body sytem is much less leak-prone and reliable. It just doesn't do as good a job cooling the oil. Many of those systems are still in service and the owner rarely even knows their car even has an oil cooler.
In either case, if yours is FUBAR, you can just ditch it. Unless you are going road racing or towing heavy loads the lack of a factory cooler system will rarely cause a problem. Even if it is a problem, running some good synthetic oil in the motor will cost less and keep enverything happy for pennies compared to trying to replicate either factory oil cooler system (and there are no parts to fail or leak).
Engine: 4++,350 & 305 CIs
Do a quick search for oil coolers. there are a few threads on this
Car: 92 camaro rs
Engine: 3.4v6 sc
well there ones i see have a hole stand alone oil cooling set up and i would like th have that on my camaro added
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i built my oil cooler setup using parts from an '83 impala cop car-the cop car sandwich adaptor is same as used on trucks of that era and probably the same as used on '90s era trucks as well,very easy to plumb to an oil radiator using -10 line and the correct AN fittings. There are several areas
on the stock adaptor that are kinda restrictive to cooler circuit flow in stock,as cast form-some die grinder work fixes that-the worst are is where the steel oil filter fitting threads into the adaptor(partly blocks the port that sends oil to the radiator) Mounted the oil radiator(made by B/W,off the cop car)underhood,LH side,relocating the charcoal canister back a bit.Airflow provided when oil cooling needed by 8"thermostatic fan-buick GN intercooler fan trimmed down and new hub built to turn with chevy citation fan motor
Setup in operation since '95 and very effective and reliable.Filter still well protected -does not jut down into harms way.
Setup in operation since '95 and very effective and reliable.Filter still well protected -does not jut down into harms way. Re: tpi 350 oil coolong setup
Wait.... you want to add a factory-style oil cooler to your V6 Camaro (says V6 in your car specs)? Totally different filter size, totally different adapters. No way to put a V8 setup on a V6. Don't know if there ever was a V6 factory oil cooler option.
Navy8125
Aug 21, 2015 09:32 AM
Sanjay
Aug 12, 2015 03:41 PM
