Shifting issues with Auto
Old Sep 22, 2012 | 08:46 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
84 T/A, 355, 700R4 tranny.
The car shifts fine when I'm jsut cruising and not driving hard.
However, if I get on it, at any speed in any gear, about 50% of the time, when it shifts from 2-3 or 3-4, it'll "miss" the gear and just spin.
For example, the other day I went to pass a ca on the way to work. Slammed the pedal down at 45mph, the car shifted down from 3rd to second and I took off. As soon as the car went to shift back to third, it shifted, I could fell it coming out of 2nd, but it never hit third, it just spun...as if I were in a manual and gunned it in neutral. I let off the gas, the RPM's came down the car made a not so nice clunk/grind sound, and went into gear.
this only happens when I'm under full throttle. If I just ease through the RPM's or gears, it shifts fine.
What could this be? Time to rebuild the tranny?
Tranny was rebuilt about 7 years ago to replace a front pump seal and I added a shift kit. I still had the 305 in it.
Old Sep 22, 2012 | 09:33 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Shifting issues with Auto
What does your transmission fluid look like, any discoloration. I might be that the 3rd and 4th gear clutches are worn out.
Old Oct 1, 2012 | 05:43 PM
dlinger's Avatar
Car: 1984 Z28 HO
Did you happen to find anything?
Old Oct 2, 2012 | 02:30 PM
Ozz1967's Avatar
Car: 1984 Trans Am
The transmission fluid is at the full mark and is a dark red, almost brown/black red, but it doesn't smell burnt.
Old Oct 2, 2012 | 02:31 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Sorry for the double post...
jklein337
Sep 19, 2018 06:23 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
Leggman1
Aug 6, 2015 04:15 AM
