Blue smoke from the engine bay...
Old Oct 22, 2012 | 12:11 PM
greekknight's Avatar
When my car is up to temperature, blue smoke and a very bad smell comes out from the engine bay area, very near from the distributor cap and the transmission dipstick. Temperature is normal, oil pressure is normal...Any ideas?
The car is a 1982 Pontiac Trans am with the crossfire engine.
Old Oct 22, 2012 | 12:51 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Re: Blue smoke from the engine bay...
Blue smoke usually comes out of the tailpipe from oil burned up in the combustion chamber. It could be that you have that going on along with a exaust leak.. or I suppose it is possible that their is an oil leak causing the smoke. It would have to be hot, so I would assume it is dripping down on the exhaust. Probably either head or oil pan, get some dye, or take it into a shop to identify the area.
Old Oct 22, 2012 | 01:45 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Could also be the gasket under the dizzy, the oil galley plug right next to it on the block or, most likely, the rear china wall/intake manifold gasket.
Old Oct 22, 2012 | 09:43 PM
cjberquist88's Avatar
Car: 1988 iroc z
Engine: 5.0 tpi
Transmission: 5 spd manual
i had an 81 with that issue, turned out my PCV was bad and it was blowing oil from the dipstick.. just a suggestion ..good luck!
Old Oct 22, 2012 | 10:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
clean eng. & eng. bay top to bottom & underside of eng. . good tune-up include the PCV system . 20-30 years of crud build-up on an eng. does not smell good . after clean & tune scour eng. for with a strong light for any oil leaks & fumes . good luck .
Old Oct 23, 2012 | 12:41 PM
Thank you very much guys!
Old Oct 23, 2012 | 02:48 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Run your hand under the back of the valve cover lip and head for leaking oil also.
Old Oct 23, 2012 | 08:26 PM
bungy74's Avatar
Car: 1992 Camaro Z28
Engine: 5.0 TPI
Transmission: auto
yea probably valve cover leaking on hot manifold. you also have the pressure sending unit back there
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 8, 2015 01:18 AM
