88' Iroc-Z turns off.any suggestions? thanks
Old Oct 27, 2012 | 09:02 PM
Iroc_87_Z's Avatar
Ok so I recently purchased an 88 Iroc-Z 305tpi and I'm having a problem with the car. Ok so here's what it's doing car turns on with no problem but if left idling for 10-15 mins it just turns off out of nowhere, while driving car again runs great no problems then all of sudden it turns off but starts back up like nothing? Please help. Car has k&n intake, msd coil, not sure on this one but has a sticker saying it has a fastchip. Other than that from what i can tell everything else is stock.
Old Oct 27, 2012 | 09:41 PM
ex-x-fire's Avatar
Re: 88' Iroc-Z turns off.any suggestions? thanks
So its stalling? Clean up the throttle body really good. You might have a iac valve thats dirty or going bad.
Old Oct 28, 2012 | 12:39 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Could be the ignition module.
Old Oct 28, 2012 | 03:02 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
usually the ignition module wont let it fire back up easilly once its warmed up a bit, but its worth a shot.
Old Oct 28, 2012 | 03:54 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
TPS? Hook a Saner up to it or a laptop, should give you everything you need.
Old Oct 28, 2012 | 05:43 AM
Iroc_87_Z's Avatar
thanks for the reply. It does randomly while the car is moving and while I'm at a light. But ill check the IAC or replace it and clean the throttle body while I'm at it
I have a 90 iroc I might just switch over the ignition module and see if it still does it
for some reason didn't think of that till now. Hahaha thanks
Old Oct 28, 2012 | 01:14 PM
Car: 1992 Camaro RS
Yeah thats what I was thinking too, but sometimes people's definition of "fire back up" can vary, and it's not the middle of summer anymore either so it's not quite as hot as it would usually be when they fail.
It's probably NOT the ignition module, you're right, but if the problem grows into something that seems to take a few minutes to resolve itself then the ign module would be the top of the list.
Old Oct 28, 2012 | 04:16 PM
ex-x-fire's Avatar
Also disable the egr valve & see if it still acts up. Maybe its getting vacuum at idle sometimes.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Trickskier
Jul 25, 2017 08:39 PM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
