10psi out of mechanical fuel pump
Car: 1991 camaro rs
Engine: 350 bored .030 over, 438rwhp 429tq
Transmission: 700r4 stage 3 race 700hp
Axle/Gears: stock axles and 3.23 gears
cars been running rough since I built it, always want to die in gear. figured I'd start with the basics. fuel ignition and compression. started with fuel as its easiest because I don't have a timing light. went to AutoZone and got a in line pressure gauge put it in and its up round 10 or 9 psi while running. cud this be why it doesn't idle in gear
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
Re: 10psi out of mechanical fuel pump
......... 10 psi might be overwhelming the float needle valves and over fueling the engine ... try an adjustable fuel pressure regulator set to no more than 7 psi ... check with the carb mfr for more exact requirements .............
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
too much pressure, you need a regulator
Car: 1991 camaro rs
I bought an AutoZone regulator max 5.5 psi. carb is an edelbrock 600. lots of people said 5 psi is great for that carb is that true. pulled a plug pure gas it was still wet with gas. I've yet to put the regulator invite is it possible the hi fuel pressure is wat was making the car die in gear
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
5 lbs should be fine, High fuel pressure causing fuel fouled plugs will cause idle issues.......
Car: 1991 camaro rs
that's wat i'm sayin so i'm gonna install a msd box and buy new, e3 plugs when I do that. how hard is it to put a msd box on hei? and do you believe that could be my idle under load issue.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
*SIGH*
Car: 1991 camaro rs
ok thank you guys I'll put it in tomorrow hopefully and let you guys know how it goes PC I don't work a double. what you guys recommend for the idle pressure
Car: 92 T/A 'vert
Car: 88 GTA
Car: 1991 camaro rs
what plugs your recommend. current plugs are autolite 26s napa that's the hottest they have
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
You dont need all that!!!!
Standard plug/std heat range is fine
HEI by itself is fine. MSD is a waste on your car
You got too much pressure you need a regulator or a differnet fuel pump altogether. 10 lbs youll still have issues period. Its too much for a carb.
Car: 1991 camaro rs
ok you guys are great. keeping me from wasting money on stuff I may not need. I'll do the regulator and c wat it does
theshackle
Mar 5, 2017 06:37 PM
