oil pan gasket removal ?
Old Jan 5, 2013 | 11:35 AM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
So i got to change my oil pan gasket (1-peice) on the iroc and the rear main seal ( 2-peice)
Just wanted to make sure i didnt fk anything up. but i disconected the crossover pipe at both manifolds, took the diz off, dust pan, starter, and the engine mount bolts. now am gona jack it with a block of wood on the oil pan. but the only thing i was wondering was (do any of you take out the trans mount bolt), cause wouldnt that sht be lock into place as i jack the engine up.
but other than that any of yall got any tips or tricks for this job ?
(1985 Iroc-Z L69 Small Block 305 4bbl H.O.)
Old Jan 5, 2013 | 12:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil pan gasket removal ?
The transmission mount is flexible enough to allow several inches of lift on the engine.
Old Jan 5, 2013 | 12:24 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
You wont be able to get the pan completely out but enough to get the job done.
Old Jan 5, 2013 | 12:28 PM
Shep5B's Avatar
Well. Do you think they will be enough room for me to do the rear main seal. If not. Couldnt i just drop the trans and get more clearence to take the oil pan out?
Old Jan 5, 2013 | 03:50 PM
Shep5B's Avatar
Old Jan 5, 2013 | 06:53 PM
Did your keyboard get stuck? You will have room to drop the rear main cap and change the seal.
Old Jan 5, 2013 | 07:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You have a 1 piece pan gasket and a 2 piece rear seal?
Or your replacing your multi part pan gasket with a 1piece gasket?
Old Jan 5, 2013 | 09:54 PM
Shep5B's Avatar
Yep. Thas correct. Am changing the 4 peice old Oil pan gasket with a new 1 peice Oil pan gasket from fel-pro. And also my rear main is a 2 peice
Old Jan 6, 2013 | 12:27 AM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
You can get the pan out if you know exactly what you are doing! It takes some work but if you get it just right itll slide right out but it takes some work! Just be prepared!
Old Jan 6, 2013 | 01:16 AM
TTOP350's Avatar
10-4, its quite a job to do in the car. I have a one piece felpro on my "older" block.
I would also get longer pan bolts and pan rail stiffener bars like the 87ish and up motors have.
I had problems keeping the pan rails sealed until I did that.
Its a big job but not hard. good luck
Old Jan 6, 2013 | 02:55 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I just replaced a leaking 2-piece seal, already had a 1-piece pan gasket
My 2 cents:
I use anarobic gasket maker instead of RTV for the bearing cap, in cold weather the Surface Prep Activator is a must, if you don't have a heated garage.
Let it set for a several hours so the most of the oil drains into the pan.
Remove the bolt that connects the trans mount to the trans cross member. You may have to rotate crank as you pull the pan out past the engine cross member.
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
