carb to big?
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
carb to big?
im looking for a new carb this week for my current setup. i want to get the edl-1407 750 cfm carb but not sure if its to big. i currently have a 600 cfm but its seen its better days. any advise?
current engine:
355 sbc
air gap intake
cam .488/.510
210cc 2.02 valve aluminum heads
roller rockers
headers
msd box
hei dist
current engine:
355 sbc
air gap intake
cam .488/.510
roller rockers
headers
msd box
hei dist
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb to big?
A 750 isn't too big by any means. You might consider upgrading to a DP, but if you're more comfortable tuning Edelbrocks you can stick with one of those.
Engine: 355
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: carb to big?
Aftermarket support. When you want to start tuning or modifying the carb, a Holley style is the way to go. There's lots of carbs out there based on the Holley design. Edlebrock is based off the old Carter AFB and nobody else makes versions like that.
They both have their own advantages and disadvantages but the Holley style is more preferred. Even looking at a basic 750 carb. There's probably at least a dozen different list numbers for a Holley 750. Not all are the same and they all perform differently. At least you didn't suggest the Holley 3310. They need to stop making that old carb.
Not sure if the Barry Grant Demon carbs are still available. They had a lot of good design ideas that Holley should have done decades ago.
Engine: 355
Re: carb to big?
will the 4160 holley model work for my application, or the 4150 series? i was also looking at the 670 street avenger, will that be better for street/strip? i race maybe 5 times a year and want street performance with help at strip
Engine: 355
Re: carb to big?
