Temperamental car
Old Feb 21, 2013 | 06:02 PM
Zpowell96's Avatar
Car: 1992 camaro rs
Engine: V6 3.1
Transmission: Automatic
Temperamental car
So first off I bought my car about a month ago. It's a 1992 camaro rs. V6 3.1
It idles anywhere from 1100- 1400 which seems way to high for me. It runs good after it warms up but the idle is still always high lowest I've ever seen it was 800 and it was only for a couple seconds. Yes the check engine light is on I bought a code reader and it should be here tomorrow. The guy I bought it from said there was a problem with the computer. I went to pick up my girlfriend, and the car was running perfect. When I got a block away from home it died and wouldn't restart, I waited 2 minutes and tried again then decided to push it the one block. I went out a couple hours later and it started right up. Anyone have any ideas?
Old Feb 21, 2013 | 06:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Temperamental car
a code reader is a waste of money jumper the aldl a to b terminal. a high idle would be caused by a faulty or dirty iac, vacuum leak or throttle blade binding.
Old Feb 21, 2013 | 06:25 PM
Zpowell96's Avatar
Car: 1992 camaro rs
Engine: V6 3.1
What's the best/easiest way to find if you have a vacuum leak?
Old Feb 21, 2013 | 06:31 PM
Engine: Lb9
Transmission: M20
propaine enrichment or spray carb and choke cleaner around the throttlebody mounting surface and around the plenum and manifold to cylinder heads.
Old Feb 21, 2013 | 07:20 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Originally Posted by Zpowell96
...a code reader
I need to master the jumper-method too: https://www.thirdgen.org/service-eng...ht-error-codes
Old Feb 21, 2013 | 07:55 PM
Zpowell96's Avatar
Car: 1992 camaro rs
Engine: V6 3.1
Oh yeah. Also after driving for a while it doesn't want to leave after stoping. I drove for 10 miles and when I stopped at the light it was real skittish and acted like it wasn't getting much gas. It does this pretty much every trip I've drove in this car.
Old Feb 21, 2013 | 08:52 PM
W.E.G.'s Avatar
Engine: V6 2.8
Get your codes.
Find the gizzy that sends them, and test or replace the gizzy as your abilities and budget will allow.
Intermittent gremlin problems can often be something as simple as a bad ground connection.
Old Feb 21, 2013 | 09:14 PM
Engine: Lb9
Transmission: M20
Originally Posted by W.E.G.
Get your codes.
Gizzy
Old Feb 21, 2013 | 09:33 PM
W.E.G.'s Avatar
Engine: V6 2.8
Gizzy list:
TROUBLE CODES
12.
No reference pulses to Electronic Control Module (ECM).
13.
Oxygen sensor signal stays lean during warm engine cruise
14.
High temperature indicated at engine coolant temp sensor
15.
Low temperature indicated at engine coolant temp sensor
16.
High battery voltage OR Direct inition system open or shorted to ground
17.
RPM signal problem
18-20.
N/A
21.
High voltage at throttle positon sensor
22.
Low voltage at throttle positon sensor OR Fuel cutoff relay circuit open or shorted to ground
23.
Low temperature at manifold air temperature sensor OR Throttle position sensor error
24.
Circuit fault in vehicle speed sensor
25.
High temperature at manifold air temperature sensor OR Vacuum switching valve circuit open or shorted to ground OR High voltage at ATS sensor
26.
Fault in quad driver module
27.
Fault in 2nd gear switch
28.
Fault in 3rd gear switch
29.
Fault in 4th gear switch
30.
N/A
31.
Low voltage at manifold absolute pressure sensor OR Fuel injector OR Park or neutral switch OR CAM diagnostic OR Governor malfunction OR Wastegate overboost OR Wastegate eletrical signal open or shorted to ground
32.
Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch OR Fault in electronic vacuum regulator valve
33.
High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34.
Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35.
Idle speed can not be set to desired RPM
36.
Burn off at mass air flow sensor OR Problem in transmission shift OR Fault in direct ignition system OR Missing pulses in electronic spark timing signal
37.
N/A
38.
Fault in torque converter clutch brake switch
39.
Fault in torque converter clutch circuit
40.
N/A
41.
Fault at cam sensor OR Cylinder select error OR Tach input error
42.
Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
43.
Low voltage at electronic spark timing circuit
44.
Oxygen sensor lean
45.
Oxygen sensor rich
46.
Fault at vehicle anti-theft sytem OR Fault at power steering switch
47.
Problem at Electronic Control Module (ECM)
48.
Misfire
49.
Vacuum leak
50.
N/A
51.
PROM error
52.
Problem at Electronic Control Module (ECM) - Missing fuel calpac missing OR Analog to digital converter error OR Fault at quad driver module OR Low voltage at oil temperature sensor
53.
High voltage at battery OR High voltage at exhaust gas recirculation valve OR Voltage reference error OR Problem at vehicle anti-theft system
54.
Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
55.
Problem at Electronic Control Module (ECM) - ECM failure OR Serial bus error OR Fuel lean malfunction
56.
Low coolant or corrosivity OR Fault in port throttle system vacuum sensor
57.
N/A
58.
59-60.
N/A
61.
Oxygen sensor degraded OR Port throttle system error OR Cruise control problems
62.
Gear switch input diagnostics OR High voltage at oil temperature sensor OR Fault in cruise control- vacuum solenoid circuit
63.
High voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Fault at right oxygen sensor
64.
Low voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Right oxygen sensor lean
65.
Failure at exhaust gas recirculation valve OR Faulure at injector peak/hold diagnostic OR Right oxygen sensor rich OR Fault at cruise control position sensor
66.
Internal reset of Electronic Control Module (ECM)
67.
Fault at cruise control switch
68.
69.
Fault at air conditioner pressure switch
70-87.
N/A
88.
Old Feb 21, 2013 | 10:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
try changing your fuel filter .
Old Feb 23, 2013 | 06:54 PM
Zpowell96's Avatar
Car: 1992 camaro rs
Engine: V6 3.1
I'm planning on changing the fuel filter once the 13 inches of snow we just got melts, because I don't have a garage. And I just scanned for codes but because its been parked for a couple days nothing came up. Ill drive it around and check it again once the snow is gone.
Old Mar 10, 2013 | 01:16 PM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Axle/Gears: 10 bolt with 3.73
Originally Posted by tunedperformanc
Gizzy
I was thinking the same thing.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
