Sump (Oil Pan?) differences.
Old Mar 2, 2013 | 08:34 PM
Cosmik Debris's Avatar
Is there any difference between a thirdgen sump and any old aftermarket sump that you can purchase from any auto parts place?
Thanks.
Old Mar 2, 2013 | 09:12 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
Re: Sump (Oil Pan?) differences.
Thanks.
Do you mean cosmetically, fitment, or performance wise?
As long as it is actually for the correct application Id think no for the first two. Performance has alot to do with the brand and sadly the price of said aftermarket pump.
Old Mar 2, 2013 | 10:34 PM
I was thinking fitment wise. I can't see a problem but I thought I'd ask.
Old Mar 2, 2013 | 10:43 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
I think you should be fine
Old Mar 3, 2013 | 02:01 PM
I notice that some places sell sumps for 55 - 79 and 87 up. Do things like rear main seal and dipstick position make a difference in the sump?
Old Mar 3, 2013 | 06:25 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I think there is an issue with some aftermarket sumps not clearing the k-member, from what I recall from my browsings here. Seem to remember reading about members here having to notch sumps or k-members for fit.Try searching it.
Old Mar 3, 2013 | 07:46 PM
Actually I think that is what I was thinking of. I vaguely remember something about this which is why I asked.
Old Mar 3, 2013 | 08:04 PM
skinny z's Avatar
The oil pan for a non 3rd gen application will most likely make contactr with the k-member. Not all but most.
There is also hard contact with the inner tie-rod ends when the steering is turned lock to lock. You'll notice that a 3rd gen pan has pronounced directly adjacent to the steering linkage.
This is a note from experience as I was going to swap in a fresh "generic" pan that had been given to me only to find it wasn't going to work.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
