Lift and rocker ratio question
Old Mar 15, 2013 | 07:39 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
I'm going to put a comp cams XR264HR with .48/.49 lift in my vortec 350 and I'd perfer not to machine the heads for clearance so I was going to use Crane Cam’s 10309-1 spring and retainer kit which is supposedly good for .550 lift on the vortec heads.
Now when they say the kit is good for .550 lift, does that mean it won't be able to handle the XR264 cam because after considering the rocker arm ratio, I'll be at .735 lift? Am I missing something in my calculations? I will use scorpion full roller rockers 1.5 ratio.
Thanks.
Old Mar 15, 2013 | 08:38 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: Lift and rocker ratio question
Thanks.
Are you using a stock rocker arm, roller tip rocker, 1.52 rocker, 1.6 rocker?
Old Mar 15, 2013 | 09:06 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Lobe lift multiplied by rocker ratio gives you valve lift. (Calculated) actual lift at the valve may vary, especially with solid lifter cams. The .480/.490" figures are valve lift typically with a stock rocker ratio of 1.5:1.
Old Mar 15, 2013 | 09:07 PM
RWO3's Avatar
Engine: 355
Axle/Gears: 3.08
I will use 1.5 ratio full roller rockers.
Old Mar 15, 2013 | 09:10 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Um ya no need to add the rocker arm ratio to your cam lift. So your valves will only move .480/.490 so the. 550 springs will work.
Old Mar 16, 2013 | 03:23 PM
Cosmik Debris's Avatar
The lift you have quoted is the valve lift with 1.5 rockers. .48 is .512 with 1.6 rockers. Just multiply the 1.5 lift by 1.6/1.5.
Old Mar 16, 2013 | 05:13 PM
RWO3's Avatar
Engine: 355
Axle/Gears: 3.08
Ahh, ok thanks for the answers guys!
Old Mar 16, 2013 | 06:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your 0.480/0.490 valve lift is quoted by using a standard 1.5 rocker ratio. The lobe lift is .480/1.5 = 0.320 and the .490 is 0.326. Now, knowing the lob lift, you multiply it by the new ratio of 1.6 and get a valve lift of 0.512/.521
Instead of worrying about pushrod clearance through the head by using a 1.6 rocker which will move the pushrod closer to the pedestal, why don't you just buy a cam that will give you the same lift with 1.5 rockers?
Using an increased rocker ratio is just a poor mans cam swap. If you're going to change the cam, get a grind to match the lift you're shooting for. There is a time when an increased rocker ratio can be beneficial so that you don't have to use a real small base circle cam but you're nowhere near that range.
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
IrocZ'85
Aug 17, 2015 06:24 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
