Battery is good. No crank after driving around.
Old Apr 8, 2013 | 11:49 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
This one is a confusing one. My battery is brand new. Alternator is new and has a voltage of +- 14 volts in idle. When the Camaro is "cold", she cranks fine. But when after I turn off the IROC after a good 1/2 hour of driving, she wont crank at all. Voltage is normal. No click or anything. Then after a couple hours of cooling down, she will turn over and start? What may be the issue here?
Old Apr 9, 2013 | 10:22 PM
Re: Battery is good. No crank after driving around.
Bump
Old Apr 9, 2013 | 10:24 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Ignition control module usually has similar symptoms when nearing failure
Old Apr 9, 2013 | 10:36 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Heat soak on the starter
Old Apr 9, 2013 | 10:51 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Old Apr 9, 2013 | 10:52 PM
Jcodello's Avatar
Car: 1992 Firebird
Engine: Had a LO3 305 am now building a 355
Transmission: 4l60
Axle/Gears: 2.73 one wheel spinner...for now
I used to have a similar issue. Mine was over heated starter with my timing being too far advanced.
Old Apr 9, 2013 | 10:53 PM
Cool. Thanks guys. Time to buy one of those thermo wraps for the starter.
Old Apr 9, 2013 | 10:54 PM
Ill definitely look into this too. Thanks for the reply Javier.
Old Apr 9, 2013 | 11:05 PM
Jcodello's Avatar
Car: 1992 Firebird
Transmission: 4l60
FYI, they do make a head shroud that mounts around the solenoid. I bought one for mine and seemed to help.
Old Apr 9, 2013 | 11:07 PM
I do have a shield that looks something like this,,,,
But for added insurance, I would like to add this wrap too,,,
Old Apr 9, 2013 | 11:08 PM
Do you have a part number for the one you bought?
Old Apr 9, 2013 | 11:15 PM
Jcodello's Avatar
Car: 1992 Firebird
Transmission: 4l60
http://www.autozone.com/autozone/acc...mString=search
Old Apr 9, 2013 | 11:33 PM
TTOP350's Avatar
I would get a high torq mini starter..
Old Apr 10, 2013 | 10:05 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
had a similar problem. coil was going bad. just another option if options a and b dont work
Old Apr 10, 2013 | 10:58 AM
Old Apr 10, 2013 | 10:59 AM
Cool.
Old Apr 10, 2013 | 11:00 AM
Coil is good. Only 3 years old.
Old Apr 10, 2013 | 05:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
after driving, she wont crank at all.
after cooling down, she will turn over and start?
Well documented SBC problem
https://www.thirdgen.org/solenoid
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
