1986 Iroc z Code 46
Old Apr 21, 2013 | 11:27 AM
Teague's Avatar
1986 Iroc z Code 46
Ok so I just finished doing a engine swap from a 305 to a 350.
I replaced the Injectors, ESC, Knock sensor and Prom.
The issue I am having now is that my car won't start, and I am getting a code 46 (VATS). Now as far as I know 86 Iroc's didn't have vats, however, the Prom I got is from a 88, is this why I'm getting a code 46? And if so is there any way around it or do I need to get the Prom re programed?
The car will crank and sputter for a sec. There is spark and good fuel pressure and if I spry starter fluid it will run till the fluid is gone.
Any help or comments appreciated.
Old Apr 21, 2013 | 11:30 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1986 Iroc z Code 46
what are the letters on top of the memcal ?
Old Apr 21, 2013 | 11:34 AM
Teague's Avatar
I will have to check. Is that one of the numbers you can see through the top of the chip?
Old Apr 21, 2013 | 11:39 AM
Engine: Lb9
Transmission: M20
Those are the ones, late 88 and 89 contain vats as well as 86-89 vetts. You can have it reprogramed or buy a bypass module thats send a hz signal to the ecm to enable the injectors.
Old Apr 21, 2013 | 11:41 AM
Teague's Avatar
Thanks for the info. I will go get the numbers later today.
Old Apr 21, 2013 | 12:12 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tech...-i-bypass.html
You will not have anything in b6 of the ecm
Old Apr 21, 2013 | 09:26 PM
Teague's Avatar
Thanks for the link. I'm a little confused as to which part of it applies to me.
Old Apr 21, 2013 | 09:47 PM
Engine: Lb9
Transmission: M20
This would be one way to bypass it.
http://www.ebay.com/itm/GM-VATS-or-PASSkey-II-Bypass-Module-For-LS1-and-LT1-/281056694861?vxp=mtr
Old Apr 21, 2013 | 11:10 PM
Teague's Avatar
Ah I see. So I could plug one of these into B6 on my ECM?
Old Apr 21, 2013 | 11:17 PM
Engine: Lb9
Transmission: M20
Yes, you can send the 30hz signal to b6 of your ecm but you will need to go to the junk yard and un pin a connecter to slide into b6. Your only to options would be this bypass or have the memcal reprogramed.
Old Apr 21, 2013 | 11:43 PM
Teague's Avatar
Ok got it. Oh, and thanks for your help.
How hard is it to get thel memcal reprogramed?
Old Apr 21, 2013 | 11:46 PM
Engine: Lb9
Transmission: M20
Its not hrs to have the memcal reprogramed al all, I offer that service for a reasonable price.
Old Apr 21, 2013 | 11:54 PM
Teague's Avatar
Send me a private message about that.
Old Apr 22, 2013 | 09:37 AM
Teague's Avatar
I think it would be easier to get the memcal reprogramed than try and bypass the VATS.
Old Apr 22, 2013 | 11:08 AM
Engine: Lb9
Transmission: M20
Pm sent
Steven 86IROC-Z
May 24, 2026 04:52 AM
michealleger
Aug 26, 2015 03:29 PM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
