1/4 run?
Old Apr 26, 2013 | 05:42 PM
Camaro199677's Avatar
Car: 1985 Camaro Z28
Engine: Work In Progress
Transmission: 700R4/2200 stall/Shift Kit
Axle/Gears: 7.5 Richmond 3.73/Gov Loc Posi
1/4 run?
I'm pretty bored and am just curious on what everyone thinks my car will run when it is all finished. I am really hoping for low 12's. The car is a 1985 camaro t-top with no air conditioning and no back seats. I am in the process of the build and have came a long way but money is tight so it is going to be a while before EVERYTHING is finished. But here is a list of everything it is going to have.
ENGINE:
-355 4 bolt 10.0:1 Compression
-Lunati Voodoo Hydraulic Flat Tappet 276/284 duration .501/.525 lift 2200-6400
-1.5 full roller rockers
-Weiand X-CELerator single plane intake manifold 2000-6500
-190cc 64cc Pro Comp heads (from skipwhite performance) with 2.02/1.6 PBM valves and .550 lift springs
-Holley 750cfm (not double pumper)
-3 core radiator with dual electric fans
TRANSMISSION
-700R4 Built to handle 500+ horsepower
-2200 stall (transmission builder says that it will work fine with my cam)
-Stage 2 shift kit
-B&M Mega Shifter with reverse lockout and neutral safety switch
REAR END
-7.625 10 bolt
-3.73 Yukon gears
-Yukon Dura Grip Positraction
-Yukon 28 Spline Axles
SUSPENSION
-KYB gas struts
-KYB gas shocks
-Polyurethane Front/Rear Sway bar bushings and end links
TIRES/WHEELS
-Weld Pro Stars 15-8/6
-215/60R15 BF Goodrich Radial T/A
-275/60R15 Hoosier Drag Radials
EXHAUST
-Hooker Competition Shorty Headers 1 5/8inch
-Dual 3" pipes into a 3" X pipe into the mufflers then dumped before the back tires
-Dynomax Glasspack Bullet Mufflers
Old Apr 26, 2013 | 06:25 PM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
14.20@96
lmao jk
Posted from Thirdgen.org App for Android
Old Apr 26, 2013 | 07:13 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: 1/4 run?
Not a bad combo at all.
One of my buddies has a very similar 355 in his 1970 Nova, but with old-school "double hump" heads. Same exact cam you have, RPM Air Gap, 700 Holley DP, 3.73's, and a 3000 stall. The car runs and sounds great, makes for a fun weekend toy.
On crappy street tires with a 60' best measured with a calendar he still managed an 8.50 1/8th at 85mph. Going on my completely unscientific butt-dyno analysis I think with a set of real tires it'd run 7.8-7.9 in the 1/8th, which converts to a ~12.35 1/4 IIRC.
Old Apr 27, 2013 | 12:29 PM
Re: 1/4 run?
Yeah I'm building the car for to be fun weekend car but am curious what everyone will think it will run. Thanks for your input that's really awesome. I wish I had a nova haha
Old Apr 28, 2013 | 05:24 PM
Re: 1/4 run?
Anyone else got an opinion?
Old Apr 28, 2013 | 05:40 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 1/4 run?
my guess is right around 13s, high 12s maybe... sorry there just isnt really anything special in that engine...
Old Apr 28, 2013 | 06:49 PM
Re: 1/4 run?
Oh ok. What would you suggest to get it in the low 12's?
Old Apr 28, 2013 | 09:11 PM
Car: 91 RS
Engine: 350 vortec
Re: 1/4 run?
spray... or be willing to spend more money
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
