350 timing chain removal
Old May 3, 2013 | 08:28 PM
87tunedport's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0
not sure if this goes under TPI or general tech section but is TPI 350 in my 87, and im exploring an idea of low idle. my mechanic told me a couple weeks ago that the timing chain was slapping and should be replaced. i believed this cause its making a chattering noise in the front of the engine. what do i need to do/remove to get to the timing chain to replace? is the damper pulley PITA to get off like on Fords?
Old May 3, 2013 | 08:45 PM
Re: 350 timing chain removal
Water pump (and whatever accessories block it), damper, timing cover. Whatever stuff like fan, wiring, hoses, etc. you encounter along the way.
It's a REAL PITA. Might take 3 hours if you're as slow as me. You can probably do it faster.
Good time to renew all the fail-with-time-and-use parts like rad & heater hoses, belts, etc. that you encounter along the way. Including the water pump; as cheeeeeeeeep as they are. No sense putting one that only has like 2 weeks to live back on there and being granted the exclusive privilege of doing it all, ALL OVER AGAIN, before the car even quits smelling of the sealant you used this time.
Old May 4, 2013 | 07:58 AM
Engine: 5.0
ok thanks, water pump was replaced a few weeks ago already cause it died on me along with heater hoses. i put a new radiator in with new upper and lower hoses. and replaced one of the drive belts when i first bought the car, but ill take a look and other belts to see it they will be going out soon. how hard is it to get crank pulley and damper off? do i need to wedge the flywheel from turning?
Old May 4, 2013 | 08:11 AM
ex-x-fire's Avatar
You need pullers to remove the dampner & lower gear, need a installer for the dampner too.
I'd do a timing chain slack test before taking it apart. Turn the engine over by hand till the timing mark is at 0, remove the dist. cap, watch the rotor as you turn the engine back & forth, look at the timing tab to is when the slack is taken up. You should have a couple of degrees, 5 or more is getting up there.
Attached Thumbnails 350 timing chain removal-untitled.png   350 timing chain removal-imagescayyc5wh.jpg   350 timing chain removal-4-27-04-001.jpg
Old May 4, 2013 | 08:13 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Hit AZ or one of the others for the damper removal and installer tool on loan. Piece of cake. Get the puller to remove the crank sprocket too.
Old May 4, 2013 | 08:32 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Buy a repair manual while you're at it.
Old May 5, 2013 | 12:20 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
One fast and easy way to remove the crank sprocket is a cold chisel; often when replacing these they are fairly brittle and will crack with a solid tap, then slide right off the end of the crank. Can be a time/tool saver.
Old May 5, 2013 | 12:31 PM
Car: 1971 Camaro
Engine: 427
I've always heard that, but never had any luck when I tried it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
3rdgenparts
Aug 8, 2015 07:09 PM
