Part identification
Old May 5, 2013 | 04:17 AM
djjon76's Avatar
Car: '84 Trans Am
Part identification
Hi all.
Can anyone ID the below?
As I have changed to non CC setup, I am wondering if this is needed? It doesn't seemed to of effected the car with it off.
Cheers.
Old May 5, 2013 | 06:30 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Part identification
That's a vac switch, not sure about '84 circuitry but I'd hazard a guess it's part of the cruise control or tcc lockup.
Old May 5, 2013 | 09:52 PM
djjon76's Avatar
Car: '84 Trans Am
Well, its not made any difference to the running, so its coming out :-)
I am guessing as well, that as I now have no need for the ECM, that most other stuff on the firewall can come out. The Mass airflow stuff etc?
As i was working on the car yesterday, I discovered most of it wasn't connected anyway.
Old May 6, 2013 | 08:13 AM
OrangeBird's Avatar
Car: 1989 Firebird
Have ya driven it lately ? If so , has the lockup in the torque converter worked properly ? I get the feeling that you have not driven it by the "its not made any difference in the running" statement and that your converter ain't gonna work right without that part .
Old May 6, 2013 | 08:35 AM
djjon76's Avatar
Car: '84 Trans Am
I should clarify.... The vacuum tube wasn't actually connected to anything before i pulled it. It just had a t piece in the end. The relay thing was connected but I've got no idea what it was / is for.
Old May 6, 2013 | 10:44 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Fairly certain its for the TQ converter lockup..
Old May 6, 2013 | 10:13 PM
djjon76's Avatar
Car: '84 Trans Am
Think I've worked it out.... It's the vacuum hose for the hood lourve thing.
Not sure if the relay next to it has anything to do with that as well though.
Old May 10, 2013 | 11:29 PM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
The relay next to it looks like 14039663. I believe it is the Throttle Kicker Relay or Idle Speed Control. Yes the two have a connection through the brn/white wire.
Old May 10, 2013 | 11:38 PM
djjon76's Avatar
Car: '84 Trans Am
Cheers. I am guessing it is useless now that I don't have the computer hooked up?
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
