crank will not move?!
I am building a 355 right now I just got the heads on, and was trying to turn the crank so I could fix the timing, and put the rocker arms on, but could not get the crank to move more then about a quarter of a spin. So how can I get it to move so I can fix my timing?
It was able to turn till I put my heads on. The heads are all torqued down to spec. To turn the crank I was just using the crank bolt and my breaker bar
Re: crank will not move?!
I have not pulled the heads off yet, but I stopped by my garage one the way home from dropping a kids off at school to see if I could see were its getting caught at. When I turn the crank it looks like the number 7 piston is hitting the head and if I turn it the other way number 8 is hitting the head Could this mean This is an issue with heads or Block
Engine: 4++,350 & 305 CIs
We need more info, what heads, what block, crank, rods, pistons and head gaskets?
Do you have plugs in the heads? Valves adjusted propperly?
Yes it could possibly mean that there's an issue. Yes could possibly be the heads or the block. Most likely not however, prolly something else.
Pop the heads off and see what's going on. Prepare yourself mentally for being about to go ALOT farther back into it.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
did you put any rocker arms on yet?
if so, is the timing chain lined up properly- dot to dot is TDC on the compression stroke of cylinder #6.
Head gasket cause it came in my rebuld kit... Let be a little more descriptive on what happening
I thought my buddy had set running cause he was playing around with it... So I put my heads on it I did not notice till I went to adjust rocker arms that it was not set... So I loosened all the arms just so they stay on. After that I went to turn crank to line up dots and it would spin just enough for 7 to teach tdc then crank stops and bolt will now spin a again but crank stay in place... I then turned it other direction to see if it what was going on and did same thing... So I only got go movment between thoose spots.. is it possiblethat the threading is bad and there's just more tension on bolt when at top of cylinder so its just spinning
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Did you tighten the main caps and the rod caps to spec?? i finished rebuilding my 355 and my crank was really hard to turn also but i was able to turn it. make sure your rods and main caps are torqued to spec and make sure to you assembly lube!
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Are the dots on the timing gears lined up? If not, fix that ,before you do real damage.
Car: 1971 Camaro
Engine: 427
A bent crank can be.
Engine: none
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Find a known flat clean surface-- roll the pushrods across it watching for wobble & straightness.
Car: '87 Camaro
Stripping the threads??
Stop what you're doing-- take the heads off.
Take the crank damper bolt out & check the threads inside & check the bolt thread.
This is exactly why 1 person only should assemble a motor. That way, he // she knows what iz done // needs to be done.
Car: 86 Camaro
does it turn if you use a screwdriver to turn the flexplate?
fyi: the crank bolt is not supposed to be used to turn the engine over.. it's purpose is to hold the damper and crank pulley in place, not to turn the engine over..
Car: 87 iroc-z
Engine: 454
Transmission: th350
glad to hear you got it figured out.
years ago i had a machine shop turn a crank, and they gave me a set of rod and main bearings with it when i picked it up. turns out they gave me the wrong size rod bearings.
gotta check everything twice.
Didn't you check your bearing clearances??? was it a stroker crank?? How did you get all the rod caps on without turning the motor over? (should be done with very newly installed main or rod cap).
Car: check
Engine: check
Transmission: check
RBob.
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Well stock 350 stroke is 3.48 so it sounds u were given a 383 crank. Wish I got that screw up. Lol
I would be doing a lot of checking with the proper tools. I hope you didnt get a 305 crank this time, they are balanced diff than a 350..
I hope you had it all balanced anyway..
