Bolt missing, don't know what its for, HELP!
Old Jun 1, 2013 | 07:50 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I was swapping out the thermostat the other day and found a hold missing its bolt on the drivers side of the engine just under the throttle to the carb. I have no idea what it does or if it is vital for the engine, can anyone help. I can get a better pic if needed. Name:  20130601_183625_zpsa866e40c.jpg
Old Jun 1, 2013 | 08:11 PM
Damon's Avatar
Re: Bolt missing, don't know what its for, HELP!
Nothing's missing. It's an UNUSED bolt hole in the intake for your application. Way back in the old days they used it to attach a big-ol' bracket for ancient axial-style A/C compressors. You're good to go.
Old Jun 2, 2013 | 10:19 PM
Dabesiv's Avatar
Alright thanks! I hate to be paranoid about it I just had no clue what it was for and it was freaking me out. Thanks again!
Old Jun 3, 2013 | 02:30 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you should be twice as freaked out as you are- there is another hole over there somewhere that serves as the mounting point for the other leg of the old AC bracket...
Old Jun 3, 2013 | 05:57 PM
Dabesiv's Avatar
I don't think I even want to look haha, I'm honestly tempted to go get some bolts to fill the holes so if I forget I won't panic again.
Old Jun 3, 2013 | 06:33 PM
It was also used as the attachment point for a brace for the later R-4 compressors, and in fact that bracket would have been on your car at one time.
Old Jun 4, 2013 | 06:01 PM
Damon's Avatar
Sofa- you're thinking of the very similar looking FRONT hole. The one that looks just like it but is in front of the two center intake manifold bolts. That front hole takes the A/C support brace in later cars that use radial-stye compressors.
Neither hole will leak anything. They both go through to the intake flange, but they dead-end against the intake gasket.
Old Jun 5, 2013 | 06:22 AM
No... there is most definitely a bracket that goes there. It is a piece of about ½" bar stock with an eye stamped into the end that goes to the intake, a coupla bends, and a little flag welded on with the other bolt hole, that bolts on top of the AC bracket.
hectre13
Dec 11, 2023 08:14 AM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Eric-86sc
Apr 3, 2016 03:52 PM
mhatfield 14
Oct 24, 2015 07:48 AM
86White_T/A305
Aug 17, 2015 12:16 AM
