Completly stumped. Starter problem.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Battery is brand new. Alternator brand new. And the starter is a brand new PowerMaster mini starter. My contacts are clean, and I also have new battery terminals.
The car starts cold every time. One time it randomly wouldn't start hot. You hear a "clunk" which sounds like the starter gear hitting they flywheel but won't crank. I did nothing but keep trying to start it, and it started 4 hours later no problem. My buddy said it didn't sound like a heat soak issue because there is starter activity, and it shouldn't take 4 hours to restart.
I wrapped the solenoid, and had no hot start problems for 2 weeks. This weekend I take a 15min drive to my fiances house. I go to restart, same thing "clunk". This time it took 8.5 hours to crank and restart (nothing was done to the car), I'm confused. After 8 hours the engine was cold. Not even warm. So I don't see how heat is playing a role. Yet it only does this on hot starts. All my starter wires run close to the header (long tubes), but they're not close to hitting, and for safe measure they're wrapped in heat shield tape. If it was a contact or wiring issue, why does it not do it ever on cold starts?
Do you guys think I just have a faulty starter? I know a lot of guys with mini starters and long tubes and they're fine and didn't even wrap there starter.
Car: 1991 Formula Firebird WS6
Engine: 350 SB TPI
Axle/Gears: 3.23 Stockers
Re: Completly stumped. Starter problem.
I wrapped the solenoid, and had no hot start problems for 2 weeks. This weekend I take a 15min drive to my fiances house. I go to restart, same thing "clunk". This time it took 8.5 hours to crank restart (nothing was done to the car), I'm confused. After 8 hours the engine was cold. Not even warm. So I don't see how heat is playing a role. Yet it only does this on hot starts. All my starter wires run close to the header (long tubes), but they're not close to hitting, and for save measure they're wrapped in heat shield tape. If it was a contact or wiring issue, why does it not do it ever on cold starts?
Car: 1988 IROC-Z
Engine: 427 SBC
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I went through something similar with a Powermaster. It would not re-start hot sometimes. Returned it under warranty and the replacement has been fine for years.
8 hours to wait, however, maybe too long for a hot soak. Either way, I'd have a look at it and like suggested above, maybe add a shim first. Too tight will encourage it to hang up after the motor starts and cause that whine, but maybe you can't hear it with that starter.
My experience with the return through Powermaster was favorable.
Car: 1988 IROC-Z
Engine: 427 SBC
I figured I'd update this for anyone that comes across this thread in the future. I finally got time to work on the car. I removed the inspection cover and my suspicions were correct. The starter gear was hitting the flex plate and not meshing. I shimmed the starter and problem solved. Starts cold and hot. Not sure why before it would start fine cold but not mesh with the flex plate when hot. I don't see the metal expanding anymore than 0.001-0.002" hot. But problem is solved. Needed quite a few shims.
Car: 1988 IROC-Z
Engine: 427 SBC
Ok last update. Shimming didn't fix it. Problem came back after a few hot starts. And I shouldn't of needed as many shims as I had in there anyway. I called Powermaster. All my voltages were good. They kept thinking it was the purple ignition switch wire. They said I should have between 9-10 volts on it when cranking. I had 9.5. And the gear popped out exactly like it was suppose to when the purple wire seen voltage. I was a little weary because the starter came with no shims or bolts (it was suppose to), and the powermaster sticker on the side of it was not there. Powermaster had me send it back and Summit sent me a new starter. It had all the bolts/shims/stickers...etc And the problem is fixed. I probably have a good 40 hot starts on it and it cranks like a champ every time.
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Doesn't it just mess up the entire logical trouble shooting procedure when the "new" part is faulty. We expect a quality part when we buy it new. Sounds like you may have gotten someone's returned part. Let us know if this one fails. Good luck with it.
Car: 1988 IROC-Z
Engine: 427 SBC
Yes I agree. The time I spent trying to figure out the issue I could have been tuning it or doing other little things like installing my heated O2 sensor. But it's nice to drive it and not worry about getting stranded.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Maybe when troubleshooting guys problems on here , we should say take the " new" part back and get a replacement as the first course of action.
I have spend way too much time on here walking newbies through diagnostics ( esp elec circuits ) only to find out in the end like the OP did
that the replacement part they bought to solve their problem was faulty.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
A lot of Powermaster stuff is refurb'ed and/or Chinese. Read the web site carefully. I had one quit pulling the drive back in completely after about only 50 starts. And, of course it started in tech inspection at the track. I $hitcanned it and bought a brand new genuine GM mini for a 96 LT1. No more cool "whine" but I expect it to outlast my old carcass.
