looking for cam help needed
Old Oct 13, 2013 | 04:17 AM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
hi everyone
im rebuilding my tpi 350 out of my 89 trans am gta. been looking for what cam to put in her for days now but just seem to be going around in circles. so im looking for a little help.
these are the mods
custom made 3 incs air intake with MAF
vortech v1 supercharger
holly large throttle body
ported plenum
ported SLP runners
ported stock heads with stock size valves
comp cams valve springs 987-16
comp cams tip roller rockers 1418-16
comp cams push rods
rebuilt stock followers
full MSD set up with 6al2 box
ecu has a chip cant remember what it is now
stock bottom end part from a new crack, piston rings and oil pump
scat balancer
theres going to be a new flex plate
flowtech headers, y pipe and cut out
also have a inline fuel pump and will be up grading the injectors soon.
so theres the mods. im looking for a cam for a bit more power and nice ruff idle sound but not to much were its cutting out in traffic end of the day she is a street car and will only go to the track now and again. would be willing to upgrade the stall converter as well if needed.
thanks for your help already
bad
Old Oct 13, 2013 | 08:19 AM
1gary's Avatar
Re: looking for cam help needed
All right here is the deal."Poser" cams with a "sound" that often don't do anything for performance and actually might hurt performance...........I hate.A sort of "like Mike",but not really.So I'm out.
I will say this.Most blower cams you find durations are conservative to capture the effect of the blower.Doesn't make any sense for a long duration for the "sound of it" to end up bleeding off the blower effect into the exhaust.In this case,home ported stock heads are where the bottleneck for flow and lift potential without machining the heads.
So there
Now you have it
And I'm out.................
Old Oct 13, 2013 | 10:24 AM
Car: 89 gta
Im not after a "poser" cam or I wouod just go for a thumper or stick with what ive got but I would like the cam to sound nice. End of the day ive got to drive it. Good sound is the plus bit of getting a new cam not just the power.
Oh and the heads were done by one of the top guys in england defo not home ported.
Old Oct 15, 2013 | 12:59 PM
Car: 89 gta
Bump
Still needing help
Old Oct 15, 2013 | 03:59 PM
Car: 89 gta
been thinking about this cam
08-433-8 comp cams
Duration 288/294, Lift .520/.540,
http://www.summitracing.com/int/part...33-8/overview/
whats your thoughts
Old Oct 15, 2013 | 06:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Tpi with a blower and if hyd roller i would consider something like a 218-224 intake duration and 10-12 deg split duration on exhaust. 112-113 lsa. You will hear some cam sound, should support mid 5500 rpm if intake is ported well, and make strong broad power.
987 springs keep lobes fairly mild, under .540" and not to aggressive like a xfi lobe.
To be honest a comp 8-305-8 would not be a bad choice and as big as i would go.
Comps blower nitrous grinds are basically what i have in mind, they have a 224/236 grind that may work well
Old Oct 15, 2013 | 11:01 PM
Car: 89 gta
Thanks that ill have a look at them when I get home tonight
dont want anything to crazy
Old Oct 17, 2013 | 12:35 PM
Car: 89 gta
Think the 224/236 comp cam could be the one. On there site it says for nitrous or small supercharger so looking go so far.
Going to look into it a bit more but could be the one
thanks
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
