freshly rebuilt oil burner
Old Oct 13, 2013 | 10:58 AM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Using a qt. every 200 mi. If my tpi intake was sucking oil from the galley would I be able to tell looking into the injector hole with a bore scope?
Old Oct 13, 2013 | 01:58 PM
Re: freshly rebuilt oil burner
Maybe... you could look to see if the gasket is folded up into the intake port. The oil itself might or might not show up.
Old Oct 13, 2013 | 02:16 PM
Twin_Turbo's Avatar
What heads? Sealant on rocker studs & studs tight?
Old Oct 13, 2013 | 04:48 PM
ex-x-fire's Avatar
It could be sucking oil there at the intake flange or even at the rocker studs holes.
Old Oct 13, 2013 | 04:55 PM
ex-x-fire's Avatar
If its a motor you put together w/ different heads then you might have a mismatch somewhere, I had a similar oil burning problem. I had to buy a felpro 2520 checker to figure it out. Basically the heads were to high. Which causes the mismatch at the intake flanges. I had 20 taken off the heads & ran a thinner head gasket. Sometimes using thicker intake gaskets help too.
Old Oct 13, 2013 | 04:57 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Was a felpro steel cored intake gasket. Dart SHP heads. Did not seal rocker studs. Hard to believe oil could get by those threads
Old Oct 13, 2013 | 05:03 PM
ex-x-fire's Avatar
I thought the same thing on the rocker studs, till I pulled them & they had a coat of oil on them. On my heads, some of the holes go through to the intake port. Plus each time the rocker opens & closes the stud flexes slightly & the ones that are under engine vacuum are the worst.
Old Oct 13, 2013 | 05:08 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Interesting about the checker. Took about .020 off the block as well.
Old Oct 13, 2013 | 05:16 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
IIRC all the intake ports had a stud hole. With the dart lengthy disclaimer , would have thought they would have mentioned to seal them. Could that much oil get by the threads? Should try that first before I pull the intake.
Old Oct 13, 2013 | 05:29 PM
Twin_Turbo's Avatar
Yes, I would check that first. Might want to pull plugs and see if they are all contaminated and if only a couplecheck the studs on those and cross reference by checking a stud on a clean cylinder. If they re slightly loose the oil consumption gets bad really quickly.
Old Oct 13, 2013 | 07:01 PM
Big mistake.
Not sure how much "that much" is, in your opinion; but, ALOT can get by there.
Vacuum on one side, crankcase on the other.
Go back and fix that mistake. No sense in "troubleshooting" any more with such a gaping mistake as that.
Use the Permatex "high temp automotive thread sealer with Teflon". NOT any kind of silicone, or gorilla snot. Both dissolve in gasoline.
Old Oct 13, 2013 | 07:03 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Some of the plugs are worse than others. The fouled section of the plug is pointed toward the intake valve. Maybe just seal the intakes? The studs are all torqued down tight. Any sealer better than an other?
Old Oct 13, 2013 | 07:17 PM
Seal them all. Why do it half-a$$ed when you're ALREADY in there ANYWAY and it basically doesn't cost another dime?
Not sure about the sealer question; maybe one of the posts farther up might shed some light on what to use and why not to use the common substitutes.
Old Oct 13, 2013 | 07:24 PM
Twin_Turbo's Avatar
loctite 567
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
