Water Leaking underneath passenger side
Old Oct 23, 2013 | 07:48 PM
Chevygurl223's Avatar
Car: 1992 Camaro RS
Transmission: 5 speed
I bought a 1992 v6 Camaro 4 days ago in near perfect condition w/only 77k miles. I drove it from Nevada to California the day I bought and have driven it to and from work the past three days w/no issues. I got home from work today and found water pooling underneath the passenger side. It does not feel or smell like coolant and I checked the passenger floorboards and they were bone dry so I am assuming its not the heater core (my last '92 had that issue). I don't have my car jack w/me so I can't get underneath to see exactly where its coming from. The transfer case looks a little wet from what I can tell which concerns me. Any ideas?
Old Oct 23, 2013 | 08:12 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Water Leaking underneath passenger side
Underneath the car?
Condensate from AC unit?
Old Oct 23, 2013 | 09:22 PM
Car: 1992 Camaro RS
Yea its underneath the car. Maybe that's it. It just seemed like a lot of water to be condensation- like a few ounces. The transfer case looked damp too...
Old Oct 24, 2013 | 12:07 AM
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
U can check right behind the engine there are two rubber hoses that go to the heater core that leak on the outside of the car while the collant system has pressure !
Old Oct 24, 2013 | 12:10 AM
THEBEAST84's Avatar
Ill get some pics in the am when it light out !!!
Old Oct 24, 2013 | 07:17 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
There's also two metal pipes that run down the passenger side frame as well that routes the heater hoses out of sight as well. Those metal pipes rust and start to leak aswell
Old Oct 24, 2013 | 06:02 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Heater hoses would leak coolant, and 223 says its water.
Might look at door seals, esp. that triangular-shaped seal at the forward base of the window.
Old Oct 25, 2013 | 05:53 PM
I seem to remember that it's called "door shield."
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
