Where can I get a breather grommet?
Old Nov 17, 2013 | 01:59 AM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
My breather hose is pretty loose at the valve cover. There's a lot of play in any direction (all 360 degrees). I've read that you can't just use a PCV valve grommet for it, even though the hole sizes are the same. So where can I get just a breather grommet for the passenger side valve cover? Besides a junkyard.
Also, a long time ago, I misplaced the metal clip that holds the breather element/filter to the air cleaner assembly. Does that matter much? The breather element/filter is so cheap, and it comes with a metal clip too. I might just buy a new one.
Old Nov 17, 2013 | 02:16 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Where can I get a breather grommet?
Gm 19110486 the breather retin can be found in the prts store help section.
Old Nov 17, 2013 | 02:40 AM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
I thought you couldn't use a PCV valve grommet in place of a breather grommet?
Old Nov 17, 2013 | 02:51 AM
Engine: Lb9
Transmission: M20
I was providing the part number for a new pcv grommet, if you want the gm pn for the desired grommet if it is still available look it up at nalley. If doesn't matter if you don't have a grommet on your crankcase ventilation hose. yeh it will allow more hot air to enter into the air filter housing but unless your restoring this aspect who cares.
http://parts.nalleygmc.com/cars/Chev...car-parts.html
Old Nov 17, 2013 | 07:40 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
I know ive bought grommets from auto zone for dirt cheap that work fine.
Old Nov 17, 2013 | 09:25 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I promise you, A rubber grommet doesn't know if there's a pipe or a PCV valve poked into it......
Old Nov 17, 2013 | 03:29 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Well after replacing the PCV valve grommet, I see what you guys are saying. Its so tight it doesnt even matter.
I got the metal clip with the new breather filter. Can anyone tell me which way it goes on? I dont remember because its been about a year since I took it off. It seems like it should be in between the filter and air cleaner, with the C opening facing down. But there are also metal marks that seem to indicate the old one was on the outside of the air cleaner in between the hose and cleaner, with the C opening facing up. I couldnt get either way to snap closed though.
Old Nov 17, 2013 | 03:47 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
T=Yes the "HELP" section at AZ or Oriellys
Pac J
May 17, 2020 10:44 AM
aaron7
Sep 30, 2015 09:15 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
sleprock
Sep 24, 2015 04:33 PM
1985chevydude
Aug 20, 2015 12:29 AM
