Can anyone identify this wire?
Old Feb 21, 2014 | 05:17 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Engine: LT1 conversion
Transmission: Rebuilt 700r4 w/2400 stall
Axle/Gears: 373
Not the best pic but this head is attached to a green wire coming from the back engine wall in the center of the engine bay.
Old Feb 21, 2014 | 05:54 PM
Re: Can anyone identify this wire?
Looks like, for the fan switch.
Old Feb 21, 2014 | 06:41 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
But if that was true wouldn't that mean the fans wouldn't work because the wire is disconnected? Because the fans do work.
Old Feb 21, 2014 | 07:18 PM
OrangeBird's Avatar
Car: 1989 Firebird
Remember , just as your fuel pump can run from either of two sources (the fuel pump relay controlled by the ECM and/or the oil pressure switch) , so too can your fans run from two sources ( the fan relay controlled by the ECM and/or the temperature switch that wire likely belongs to) .
Old Feb 21, 2014 | 09:33 PM
4mula5.oh's Avatar
Car: 1990 formula
Engine: 305 LO3
Transmission: auto
I have the same thing. I don't know either, if you find out let me know. mine was like that when I got it new
Old Feb 22, 2014 | 02:00 PM
Dgreen87's Avatar
Car: 1987 IROC-Z camaro
Engine: 305 tpi
Axle/Gears: borg-warner 3.27
if its by the coil it could be for your EGR valve sensor or its for your mat (manifold air temp) sensor. if you have tpi its under the plenum.
Old Feb 22, 2014 | 02:17 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
It is actually by the coil but I do not have TPI. I have a LT-1 manifold. Is this something that I should reconnect? The car has been running fairly well.
Old Feb 22, 2014 | 04:11 PM
Dgreen87's Avatar
Engine: 305 tpi
1 do you have a mat sensor?
2 are you shooting any codes?
3 if it runs fairly well you may not need it. theres alot of things you really dont need but the car will still run. my maf is disconnected and the car runs great so plug it in see what happens if it runs worse disconnect it. im using my 87 iroc as a reference so im thinking there is a similarity.
Old Feb 24, 2014 | 03:47 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
Dgreen87 can you give me an idea where exactly I can plug that back in? The location of the "outlet" so to speak.
Old Feb 25, 2014 | 11:58 AM
Dgreen87's Avatar
Engine: 305 tpi
ok if it is the EGR vavle sensor it should be a single wire that connects into a nut so to speak that is screwed into the EGR itself, look for the EGR and youl find it if its not that look for the mat sensor on the intake and plenum it has to go somewhere. just out of curiosity what motor did you have in your t/a before you did a swap it could be for a different motor.
Old Feb 25, 2014 | 12:00 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
I had a 305 TPI
Old Feb 25, 2014 | 12:08 PM
Dgreen87's Avatar
Engine: 305 tpi
haha ok then your looking for a conection that doesnt exist i kept going through my books on where this goes on a lt1 and then i relized GM put the wire there for a different motor. a different motor needs different sensor. i seriously doubt you need it im guessing it was for the tpi
Old Feb 25, 2014 | 12:13 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
Thanks man now I'll be able to sleep a little better!
Old Feb 25, 2014 | 07:20 PM
jrmints1415's Avatar
Car: 1985 Firebird
Engine: 2.8l V6
Transmission: 5 speed manual
I believe that is the o2 sensor wire that attaches down by the manifold but i could be mistaken...
Old Feb 27, 2014 | 11:02 AM
Dgreen87's Avatar
Engine: 305 tpi
its not an o2 connector, the connection in the pic is by the coil in the top of engine bay. if it was the o2 it would be much lower like by the exhaust manifold or cat. he's done a swap from a tpi. the tpi EGR valve sensor uses a connector like this.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
