Fuel pressure readings
Old Mar 15, 2014 | 02:41 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, so my 305 tpi has a surging idle, I have to feather gas to start it, while driving I have to give it almost full throttle to make it up a hill. I tested the fuel pressure and my readings are:
47psi with the pump priming, 41psi idling and when the motor bogs down it jumps up to around 47-50 psi until the idle corrects itself again, when I rev it the motor hesitates and the pressure jumps to 50 and then drops to 41 when the rpms climb, in gear the pressure shakes at 145. once the keys off the pressure stays around 48 and drops very slowly. Can anyone make any conclusions off that?
Old Mar 15, 2014 | 03:05 PM
TylerSteez's Avatar
Engine: 383 stroker
Re: Fuel pressure readings
Goes up to a steady 50psi on a wide open throttle run
Old Mar 15, 2014 | 04:26 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Maybe nothing to do with fuel pressure . unplug mat and see if that stops surging.
Old Mar 15, 2014 | 04:47 PM
TylerSteez's Avatar
Engine: 383 stroker
It's a maf car with a brand new maf sensor
Old Mar 15, 2014 | 04:50 PM
Engine: 5.7 l98
Sorry typo . I ment MAF. Try unplug anyway. See if you get a change...
Old Mar 16, 2014 | 12:20 PM
ex-x-fire's Avatar
Your fuel pressure reads seem ok, the reason its fluctuating at idle is the vacuum going to the regulator is fluctuating.
I'm thinking a stuck open egr valve & clogged cat converter.
Old Mar 16, 2014 | 12:22 PM
TylerSteez's Avatar
Engine: 383 stroker
I don't have a cat and I think it has something to do with the egr as well, I replaced the tps sensor and the cars running a lot better, I'll give it a week and see how it's acting before I take the plenum off and replace the egr
Old Mar 16, 2014 | 12:39 PM
ex-x-fire's Avatar
You've got to reset the tps when you replace them. The holes are slotted for that reason.
Old Mar 16, 2014 | 12:45 PM
TylerSteez's Avatar
Engine: 383 stroker
I know it's set, .5 closed around 4wot
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
