91 Camaro won't crank?
Old Mar 26, 2014 | 10:16 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Transmission: 5-SPEED
Hey guys I am new to this thread. I need help figuring out about my 91 camaro RS no sudden crank. I bought a new battery, replaced terminals and new fuses. But the problem is, whenever I tried to start the car nothing happens. The fuel pump is suppose to prime and the starter should make a clicking noise. But neither of these works? Although my headlights would work, needles in my cluster gauge would tend to move clockwise whenever I start the car. My cluster gauge wouldn't light up at night, except for INFL rest which the only thing that blinks in cluster.
Old Mar 26, 2014 | 10:33 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: 91 Camaro won't crank?
I would check connections at the starter solenoid. then I would check to make sure your getting power out of your ignition switch as well.
Old Mar 26, 2014 | 11:39 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Sounds like a vats issue if you measure the resistance of the key And unplug the vats plug at the bottom of column the wires have a orange cover see if the resistance is there
Old Mar 26, 2014 | 11:52 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Okay, how do I check for resistance? I am not good at these things. Where can I locate the orange wires? thanks for fast reply
Old Mar 27, 2014 | 01:31 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...formation.html
If the pump is not priming then you have power supply problems ; VATS only effects starter operation
Check the Ign switch operation
https://www.thirdgen.org/forums/post...71-post19.html
You might want to pull the codes and see if a VATS fault is showing
https://www.thirdgen.org/forums/tech...s-dumbies.html
Old Mar 27, 2014 | 01:33 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/elec...stor-help.html
https://www.thirdgen.org/forums/elec...plain-why.html
Old Mar 27, 2014 | 08:08 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Okay, i got the car cranking by using a screwdriver to contact the starter. Could it be the fuel pump is bad? I still don't hear it prime. Now does this have to do with the vats still? But i figured the ignition switch is bad.
Old Mar 28, 2014 | 12:31 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If the switch is bad you potentially have no power to the pump , coil or starter
Will never start off the key
you will only know if you have a VATS problem after you get the Ign switch working
Old Mar 28, 2014 | 07:38 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Oh.. okay, so definitely going to replace the ignition switch soon.
Old Apr 2, 2014 | 09:18 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Okay, I have replaced the ignition switch but still nothing happens?.. I've measured the resistance of the plug with orange wire while key is on lock. As I turned the key forward to acc position the reading stayed the same, key code #10 3.74 which means my ignition cylinder is still good?
The car is 5 speed btw.
Old Apr 4, 2014 | 05:26 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
What should I do next?
Old Apr 5, 2014 | 07:46 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Here's a video showing what exactly I'm talking about..
Old Apr 7, 2014 | 05:15 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Everyone ever going to help me still?..
Old Apr 9, 2014 | 04:41 AM
Orochimaru's Avatar
Car: 1986 Chevy Camaro Berlinetta
Engine: 305 V8 5.0 carb.
Transmission: Automatic
Axle/Gears: the kind that came with the car...
Try replacing the ignition switch, ignition lock cylinder and new distributor with cap, distributor module and distributor coil and see if that will solve the problem.
Old Apr 9, 2014 | 06:59 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Throw parts at it until you find the problem ; a excellent way of wasting $$$
Old Apr 9, 2014 | 07:04 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Doesn't help that you are running the same question in 2 different threads
https://www.thirdgen.org/forums/post...48-post58.html
Old Apr 9, 2014 | 02:25 PM
Orochimaru's Avatar
Perhaps he would not be wasting money if he has not replaced those parts.
From viewing his video it seems that the no start problem he is having is ignition related...
Old Apr 9, 2014 | 02:37 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
try sticking a resistor that matches the value of your key into the connector, with the column end still unplugged, then try starting the car, the video shows exactly what my car does when it has a vats issue, your problem could be in the wiring between that connector and the vats module
Old Apr 9, 2014 | 07:17 PM
Orochimaru's Avatar
Sorry Cam_RS I should have read your early posts. My Bad. You did replace ignition switch and your ignition lock cylinder seems to be OK. I had exactly your problem seen in your video and it has all related to ignition. But I don't have VATS. I own an 86 carb 305 V8 and no VATS on those 86's.
Hope you get your car working...
Old Apr 9, 2014 | 07:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The engine is not even cranking over so he hasn't got a far as a ignition ( spark ) problem yet
If he tests the starter circuit from one end to the other as I have suggested in several of his posts he should be able to identify
where he is loosing power to the starter solenoid
Old Apr 9, 2014 | 09:28 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
I'm not good at electrical problems, a visual image of where to test the starter circuit would be nice
Old Apr 9, 2014 | 10:47 PM
Orochimaru's Avatar
Okie Dokie vetteoz...roger dodger over and out...
Old Apr 9, 2014 | 11:28 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No can do
You have to learn to read circuit diagrams like the one I gave you here
https://www.thirdgen.org/forums/post...34-post61.html
You test for power on the yellow wire out of the Ign switch and in and out at the enable relay and the clutch switch
Old Apr 13, 2014 | 07:56 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
No can do
Update, I've bypass the vats using a resistor in two white wires but the car still won't crank? The fan works and I've tried testing for power out of the Ign switch (yellow thick wire?) enable relay (green and yellow thick wire?) and cIlutch switch which is the gray or green wire? ground to the car. I don't know if I did the test for power the right way
Old Apr 15, 2014 | 05:20 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Update, I got the car cranking by jumper wire from starter enable relay to clutch switch (purple) connector wire.
I've done the resistor trick thing, but the car wouldn't crank still. I have the right resistor reading 3.73 compare to my keys value 3.74
this is how i did mine.
http://i1048.photobucket.com/albums/...ps46e5e5c7.jpg
Besides not cranking, I can only hear the fan spinning and it would tend to slow everytime i turn the key to start position, long as I could hear a clicking noise on the starter enable relay when trying to start.
Old Jun 27, 2019 | 05:12 PM
Theycallmelew's Avatar
Not sure how old this post is but I just bought a 91 with the same issue. After some research on YouTube and other forums it's a very easy fix. Just take the panel off under the steering wheel and find the plug with a orange jacket and 2 white wires. Now I don't have a store that sells resistors so I took a couple out of an old Xbox 360. Just put two resistors together and jump both the white wires. It will bypass the security.
Old Jan 31, 2021 | 01:25 PM
Rgeddes09's Avatar
Car: 88 IROC
For anyone else trying to diagnosis this problem, first check your battery is not dead. The 1988 Camaro Shop Manual contains the following diagrams to help diagnose your issue:
https://imgur.com/a/gyjJIuT
anth_91camaro
Feb 2, 2012 08:05 PM
Jim Berry
Nov 20, 2010 11:44 PM
joepackersrock
Oct 12, 2008 05:46 PM
ponykiller92
Dec 29, 2003 03:02 PM
ogmix
Oct 19, 2003 09:45 AM
