you have 10k, what would you do?
Car: 1987 Trans Am
Engine: carb. chevy 350
Transmission: 5spd
Ok, i have an 87 Trans am, mildly built 350 carb (don't know specs), 5 speed, and posi traction. I'm willing to invest 10k into it, I'm very good with welding and fab, great at anything mechanical, and know plenty of experienced mechanics to help me if need be. What would you suggest i do to make this car just beastly while maintaining street drivability. The roads here are pretty good, so I'm not really worried about hard suspension. Personally i want to run a turbo, t56, and upgrade the suspension (don't really know what i would like to do so suggestions would be nice
) i would like to put a forged bottom end and lower the cr to around 8:1 for higher boost. Anyway, lemme know what you would do. its an iron block btw.
) i would like to put a forged bottom end and lower the cr to around 8:1 for higher boost. Anyway, lemme know what you would do. its an iron block btw. Supreme Member
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
) i would like to put a forged bottom end and lower the cr to around 8:1 for higher boost. Anyway, lemme know what you would do. its an iron block btw.91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
Car: 1987 Trans Am
Transmission: 5spd
Re: you have 10k, what would you do?
I would love to drop an lsx into it haha i guess we'll see if i can find a deal :P
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
A 9" or 12 bolt rear-end. = basically an indestructible unit. with a killer gear ratio and L.S.D./posi.
Car: 1991 firebird
Axle/Gears: 4.10
I'd say full tubular suspension , coil overs, adjustable shocks n struts , founders catalog , Moser 12 bolt with 3.23-3.42 gears t56 and 500+hp
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I would part out the thirdgen and buy an 04-06 GTO or a C5...
Trust me, been there done that with dumping money into a thirdgen.
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Yeah...if you dont have a plan of action or any idea what would make you happier with your car, You are better off gambling your cash at a casino...hey you might even double your investment...
With $10,000.. You could buy a badass LSX swapped thirdgen that is running/driving/proven reliable.. That owner may have spent 20,000+.... ....see how the cash spent depreciates QUICKLY???
Goodluck!
Goodluck!
Car: 1987 Trans Am
Transmission: 5spd
I don't give a fck about what's going to be worth or what i could buy with the money, i want something that's unique and a work of art. I don't plan on selling this car, simply building what i can from it. I want coil overs but I've heard our cars weren't really meant for them and that it's easier to sick with the spring and strut setup..??
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Get a Buick BB nail head for my wagon, and put the Buick 350X into the Bird. 50/50 split
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
If I had 10k and could only spend it on my third gen? I would buy
9inch or 12 bolt posi with either 3.42 or 3.73 gears
T56 rebuild and swap
Full blown suspension rebuild (EVERYTHING)
Ram air hood
New paint job.
Is that $10,000?
Ram air hood
New paint job.
Is that $10,000?
Engine: TBI,5.0
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
