new maf and still wont start
hey guys I got a new project to work on its a 89 IROC 305 tpi well this is my first encounter with this type of set up, this car would not start with the maf plugged in but would unplugged, so bought a maf sensor and car still wont start with the new one is there a way to test the maf did a search and haven't found anything. Or are there other things to look for ? thanks.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: new maf and still wont start
Well haven't got a code scanner yet but will get one, service manual is on the way. But I did buy a maf from oreilly's and it was a bosche but had a single fin inside could that be the wrong one
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Read
http://www.chevythunder.com/maf_code_33.htm
http://www.chevythunder.com/maf_code_34.htm
Own a paper clip?
https://www.thirdgen.org/forums/tech...s-dumbies.html
Car: 86 IROC
Engine: 5.0 TPI
make sure the wiring connector is making contact,with it running , wiggle the connector on the TPS .if it stumbles or suddenly runs well, you have your answer
